Average Availability difference in SWQL Query and Web Report Writer
Hi
I am always getting different result as compare to SWQL Query and Web Report Writer.
Mentioned is Report of Average Availability LAST MONTH.
SWQL Result:
SELECT
concat(round(avg(Availability), 2), ' %' ) as supernet
FROM Orion.ResponseTime rt
where
monthdiff(datetime,getdate())=1 and rt.Node.CustomProperties.SLA_LTE ='supernet'
Web Report Result:
  • Would you be able to test with the following queries just to see if the issue is coming from SQL/SWQL or somewhere else:
    SQL:
    SELECT ROUND(AVG(Availability),99) AS Ava FROM [dbo].[ResponseTime_CS]
    SWQL:
    SELECT ROUND(AVG(Availability), 99) AS Ava FROM Orion.ResponseTime
    If you can run this as part of:
    • Report using two data sources SQL and SWQL
    • Custom Query widget on the classical and modern dashboard
    • SWQL Studio
    • Database Manager
    There can be small differences from time to time depending on data propagation but they should sync up after 10-20 seconds (depending on environment size)
    If you can please ping me here with the results of your test.
    All the best!
  • Hi
    Dear i had opened case on SW and after long discussion i got correct SWQL script that is generating same results as orion web report.
    SELECT CONCAT(ROUND(Availability,2), ' %') AS sla_availability
    FROM
    SELECT SUM(Availability * Weight) / SUM(Weight) AS [Availability]
    FROM Orion.ResponseTime AS rt
    WHERE MONTHDIFF(TOLOCAL(DATETIME), GETDATE())=1
    AND rt.Node.CustomProperties.SLA = 'supernet lte'
