Help formatting invoking a swisverb?
I am trying to use powershell to invoke-swisverb and automate updating some alertaction's EmailTo property. Based on the examples I have found online this should be how the command should be formatted.
Invoke-SwisVerb -EntityName Orion.Actions -Verb UpdateActionsProperties -SwisConnection $swis -Arguments @(@{PropertyName = 'EmailTo';PropertyValue = 'newemail@myorg.com'},{1110,1111})
When I run the above it returns an object of XmlElement, which has a #text property that has value 'true'; however, the alert is not updated.
I have also tried the following, but with the same result (XmlElement returned, but it doesn't update the alert properties).
Invoke-SwisVerb -EntityName Orion.Actions -Verb UpdateActionsProperties -SwisConnection $swis -Arguments @(@{EmailTo='newemail@myorg.com'},{1110,1111})
Can anyone help me spot what I'm doing wrong?
  • I've never done it using the Verb myself.  I've done it using Set-SwisObject
    $Swis = Connect-Swis -Hostname myOrionServer.domain.local -UserName "myUsername" -Password "myComplexPassword"
    $OldEmail = "oldemail@myorg.com"
    $NewEmail = "newemail@myorg.com"
    # Get all alert action properties in my environment where there is an old email
    $Uris = Get-SwisData -SwisConnection $Swis -Query "SELECT Uri FROM Orion.ActionsProperties WHERE PropertyName = 'emailTo' AND PropertyValue = '$OldEmail'"
    ForEach ( $Uri in $Uris ) {
        Set-SwisObject -SwisConnection $Swis -Uri $Uri -Properties @{ PropertyValue = $NewEmail }
    The verb should work, but I've personally never tried it.
  • This worked, thank you. I guess I didn't expect each property to have its own URI.
