why does my question say it looks like spam??!?!?
I have tried posting several times same thing
here is my question:
We have some scripts that run some REST queries against Orion SDK/Rest API. These used to work but one of them started failing and when running in Postman we see toopleMetadata = null error?
The query we are trying to run is:
SELECT ContainerID, MemberPrimaryID, MemberEntityType, Name, Status, StatusInfo.StatusName FROM Orion.ContainerMembers, Orion.StatusInfo where ContainerMembers.Status = StatusInfo.StatusId and MemberEntityType = 'Orion.Groups'
This worked before but now fails:
"Message": "Value cannot be null.\r\nParameter name: toopleMetadata",
"ExceptionType": "System.ArgumentNullException",
"FullException": "System.ArgumentNullException: Value cannot be null.\r\nParameter name: toopleMetadata\r\n at SolarWinds.Data.Query.Toople..ctor(ToopleMetadata toopleMetadata)\r\n at SolarWinds.Data.Query.PhysicalQueryPlan.CrossProductOp.<GetEnumeratorInternal>d__4.MoveNext()\r\n at SolarWinds.Data.Query.QueryStatisticsEnumerator.MoveNext()\r\n at SolarWinds.Data.Query.PhysicalQueryPlan.FilterOp.<GetEnumeratorInternal>d__6.MoveNext()\r\n at SolarWinds.Data.Query.QueryStatisticsEnumerator.MoveNext()\r\n at SolarWinds.Data.Query.PhysicalQueryPlan.ProjectOp.<GetEnumeratorInternal>d__7.MoveNext()\r\n at SolarWinds.Data.Query.QueryStatisticsEnumerator.MoveNext()\r\n at SolarWinds.Data.Query.PhysicalQueryPlan.PhysicalQueryPlan.<GetEnumerator>d__4.MoveNext()\r\n at SolarWinds.InformationService.Core.InformationService.RowsCountingQueryResultReader.MoveNext()\r\n at SolarWinds.InformationService.Serialization.DataTableSerializer.Serialize(String query, IQueryExecutionPlan queryExecutionPlan, IQueryResultReader reader, Boolean isBase64EncodingAccepted, IMessageFormatterStrategy messageFormatterStrategy)\r\n at SolarWinds.InformationService.Core.InformationService.RunQuery(String query, IDictionary`2 parameters, IDataSerializer serializer, IMessageFormatterStrategy messageFormatterStrategy)"
We do another query:
SELECT Container.ContainerID as MemberPrimaryID , Container.Name, Container.Status, Container.StatusDescription, StatusInfo.StatusName FROM Orion.Container, Orion.StatusInfo where Container.ContainerID not in (SELECT ContainerMembers.MemberPrimaryID FROM Orion.ContainerMembers where MemberEntityType = 'Orion.Groups') and Container.Status = StatusInfo.StatusId order by Name
And that continues to work fine returning the correct JSON response.
Any idea why the first fails and second succeeds?
It's being detected as repeated words, which looks like spam. Enclose stuff that is code in code blocks to try and avoid this.
This looks like a bug in SWIS. I was able to reproduce this on a lab server. I have created internal issue CORE-18048 to track this.
