Hi ,
I'm trying to send an http post from our ITAM tool to Solarwinds... but I keep getting 302
Url that I'm using is <ourwebsitename>:17778/.../BulkUpdate
When I test this via Postman or Insomnia it successfully updates in SW.
I believe this has something to do with the IIS
[2021-05-31T21:33:26.250142827Z] Response status: 302 Found Response headers: [Cache-Control=private,Content-Length=204,Content-Type=text/html; charset=utf-8,Date=Mon, 31 May 2021 21:33:26 GMT,Location=/Orion/Login.aspx?ReturnUrl=%2fSolarWinds%2fInformationService%2fv3%2fJson%2fBulkUpdate,X-Content-Type-Options=nosniff,X-Frame-Options=SAMEORIGIN,X-Same-Domain=1,X-XSS-Protection=1; mode=block] Response body: Object moved Object moved to here . [2021-05-31T21:33:26.250171227Z] Request was unsuccessful [2021-05-31T21:33:26.250179727Z] Storing response data
So I've pinpointed it to the IIS, seeing that the HTTP 302 on the ISS is "Form authentication" under Authentication and when I disable it I get the 401 unauthorized message ... I'm using Authorization Base64 in the header
I've tested mutliple credentials such as orion local and windows both has admin priviliges ...which does work on either Postman / Insomnia
Any ideas on what to change or where to look at?
