Full Orion alert rule export using Powershell and OrionSDK
Orion does not yet have a way to perform a complete bulk export (full backup) of all alert rules from the web console UI.
So as of today, the only option is to use the OrionSDK.
There are several use cases on why an Orion admin might need to perform a complete alert rule export.
1. When migrating from one Orion instance to another.
2. Alert rule synchronization between multiple Orion instances.
3. Backup.
Provided below is a Windows Powershell script that will export every ENABLED alert rule from an Orion instance.
Each alert rule will be exported to individual XML files using the <ALERT NAME>-ID-<ALERT ID>.xml naming convention.
# --- ORION-ALERT-BACKUP.ps1
# --- Author: Joseph Dissmeyer, www.dissmeyer.com
# --- Last updated: 2020-01-15
# --- Reference: thwack.solarwinds.com/.../433199
# --- Save as .ps1 file in your scripts directory.
# --- How it works:
# --- Downloads all enabled alert rules from an Orion instance.
# --- Each rule is saved individually as .XML file to the same directory
# --- where the script is executed from.
# --- NOTE: This only exports alert rules that are currently ENABLED.
# Requirements:
# 1. OrionSDK. Download binaries from github.com/.../OrionSDK
# 2. An Orion basic user that has "Alert management rights" enabled.
# 3. Edit the hostname, username and password.
# Verify OrionSDK SwisSnapin presence
if (!(Get-PSSnapin -Name "SwisSnapin" -ErrorAction SilentlyContinue))
    Add-PSSnapin SwisSnapin -ErrorAction SilentlyContinue
# Define Variables
$swis = Connect-Swis -Hostname my-orion-host.domain.com -Username alertbackup -Password My_Bogu$_P@55w01d
# Get all AlertIds, add to array
$AlertList = Get-SwisData $swis "SELECT AlertId FROM Orion.AlertConfigurations WHERE Enabled = True"
$AlertIds = $AlertList -split ' '
# Iterate through the Alertids array, back up each rule found
foreach($alertid in $AlertIds){
  $alerttitle = Get-SwisData $swis "SELECT Name FROM Orion.AlertConfigurations WHERE AlertId = $alertid"
  # remove all possible 'special characters' from the alert title
  $alerttitle = $alerttitle -replace '(#|\||"|,|/|:|\<|\>|\[|\]|%|$|@|â|€|Tm|\?)', ''
  # remove all spaces from the alert title, replace with underscore
  $alerttitle = $alerttitle -replace '\s','_'
  $filename = "$alerttitle-ID-$alertid.xml"
  Set-Content $filename $ExportedAlert.InnerText
  $ExportedAlert = Invoke-SwisVerb $swis Orion.AlertConfigurations Export @($alertid)
# End script
I currently have this running as a scheduled task to backup all active alert rules daily, then commit changes to a git repository.
You may need to modify this PS script for your own environment.
This script has been tested on:
Windows 10 workstation
Windows Server 2012 R2
Windows Server 2016
  • Hi Guys..
    Where do I need to run these scripts? In the main poller?
    Could someone please explain how and where to run the script?
  • Personally, I prefer to run these on a separate machine and point it to the SolarWinds server.  That's how I tested mine.  I still need to turn this into a proper function, but it's on my list.
  • So probably a dull question but that's me....
    If I want to automate this on a weekly or whatever basis, I essentially trigger the script from a Windows Task, as I presume there is no means from within SolarWinds itself to trigger this?
  • There's no traditional "scheduler" in the Orion platform, but that doesn't mean you can't find a clever way to do it.
    Rough Idea (not tested at all):
    • Setup an alert (Alert Change Detected) for when an alert is changed (excluding the 'Alert Change Detected' alert).  Have the alert check every 1 day (instead of every 1 minute)
    • If an alert has been changed, then write an informational entry to the NetPerfMon log (for record-keeping only - we probably don't need an email when this happens).
    • As a secondary action, run the PowerShell script to export the alerts.
    Like I said before, this is completely off-the-cuff and I haven't tested it, but this logic seems sound.
  • Thanks that certainly sounds like it should/could work and worth investigating if time allows.
    My read between the lines is that the 'usual' way is to run from a scheduled windows task then. Muchas gracias.
  • Yep - only good thing (read 'good' as you like) is that the logic would be in the Orion database and it wouldn't run if it didn't detect a change.  In most environments (that I've seen) alert structure doesn't change too often, so even doing something like this monthly or weekly should be fine.  If I knew then what I know now, this is something I'd do before any upgrades (along with capturing diagnostics) because I've always been overly paranoid.
