Verb "ScheduleListResources" only works for few hours after agent installation
Hello,
The powershell verb "Orion.Nodes/ScheduleListResources" to list ressources for an agent does not always work
http://solarwinds.github.io/OrionSDK/2020.2/schema/Orion.Nodes.html#schedulelistresources
1- ScheduleListResources to obtain a taskid
2- GetScheduledListResourcesStatus on this taskid : will stay in 'unknown" forever
It only works a few hours after the installation of the agent, but after that, it will never works.
PS E:\Local\Solarwinds> $result = Invoke-SwisVerb $swis "orion.nodes" "ScheduleListResources" 3178
xmlns #text
http://schemas.datacontract.org/2004/07/SolarWinds.InformationService.Contract 34211f82-563a-4f0d-8...
PS E:\Local\Solarwinds> Invoke-SwisVerb $swis "orion.nodes" "GetScheduledListResourcesStatus" @($result.'#text', 3178)
xmlns #text
http://schemas.datacontract.org/2004/07/SolarWinds.InformationService.Contract Unknown
I have tested and reproduced this problem for month and on thousands of agents (4500)
Maybe it's a plugin or update or something else which arrive and block the good execution of "ScheduleListResources"
I need to rediscover resources for ~500 agents, and it does not work. Solarwinds "support" does not support this
