I have finally gotten around to monkeying with Orion Maps. I really like how they
work and show current bandwidth and figure out most connections. But now
I want to have my edge L3 switches show as connecting to the Internet and
I want a connector from each of those L3 switches to display the bandwidth
currently in use. I tried to download a cloud jpeg. But it ended up showing the
white background. Where can I can a cloud icon with will not show its
background? And then how do I make a connection between the L3 Cisco
switch and the cloud icon? In the absence of a cloud icon I tried just adding
a circle (better than nothing). But then the connector button at the top of the
map remained grayed out even if I selected the edge switch and the circle.
Thank you.
