I have the majority of volumes alerting off the same alarm where if the volume status is critical it raises an alarm. This captures volume issues from both volumes using the default orion disk usage threshold and volumes using custon thresholds. I want to reset the alarm when it falls say 5% below the critical threshold rather than just not being critical to prevent situations where the capacity is hovering around the threshold. Is this achievable?
