Trigger for each group member in a group?
Hello,
As a test, I created a group with nodes as group members and set the logic for the alert to be that the Group Member Status is equal to Down.  This group contains 5 group members.  The alert triggers if one of the group members goes down, but what if a 2nd group member goes down before the 1st group member is back up or before the alert is acknowledged?  Is there a way to trigger the alert EACH time a group member goes down?  It doesn't have to apply to only groups of nodes, I want to do this with all kinds of object types.  Right now, this is what happens:
Test Group
Server1
Server2
Server3
Server4
Server5
Server1 goes down; alert trigger condition is true and email is sent for Server1 being down
Server2 goes down; no alert because the trigger condition is still true from Server1 being down still
I would like to see an alert for each time a group member goes down
Parents
  • I make an alert to email me if any group member status goes down (even when there were other nodes in the group that went down before), I write my solution and wish it can help you.
    1. Make a custom property for groups as text. (e.g. chng_date)
    2. Make an alert for groups:
      • Select I want to alert on to Custom SWQL Alert (Advanced)
      • Set up your SWQL condition to Groups
      • And write the following code:
    INNER JOIN Orion.ContainerMembers cm ON Groups.ContainerID = cm.ContainerID
    INNER JOIN ORION.Nodes n ON n.NodeID = cm.MemberPrimaryID
    INNER JOIN ORION.Events e ON n.NodeID = e.NetworkNode
    WHERE NOT Groups.Status = 1 AND Groups.name LIKE '%-SITE%' AND n.Status = 2 AND e.EventType = 1 AND (datetime(Groups.customproperties.chng_date) < tolocal(e.EventTime))
    -- I made groups with "-SITE" identifier so I add Groups.name LIKE '%-SITE%’ to recognize them.
      • In reset condition select Create a special reset condition for this alert ➟ Copy condition from trigger (It is the same as setting to No reset condition – Trigger this alert each time the trigger condition is met but I had some problems with that):
      • In Trigger Actions add an action to change the chng_date value to Sortable Date (${N=Generic;M=S}).
      • And add Send an Email/Page action with the subect:
    ${N=SwisEntity;M=Name} Status is ${N=SwisEntity;M=StatusDescription} at ${N=Alerting;M=AlertTriggerTime;F=DateTime}
                   And the Message:
    ${N=Generic;M=DateTime;F=DateTime}
    NODES:
    ${SQL:SELECT cast(cast([GroupMemberFullName]as varchar(max)) + '' + ' ' + '-' + ' ' as XML), cast(cast([GroupMemberStatusName]as varchar(max)) + '' + CHAR(10) + CHAR(13) as XML) FROM  [SolarWindsOrion].[dbo].[Containers_AlertsAndReportsData] where   GroupID=${GroupID}  FOR XML PATH('')}
    3. Make reset alert for groups (to reset the groups which went up before generating jira) (I preferred to set Evaluate the trigger condition every 59 seconds
    WHERE Groups.Status = 1 AND Groups.name LIKE '%-SITE%' AND n.Status = 1 AND e.EventType = 5 AND (datetime(Groups.customproperties.chng_date) < tolocal(e.EventTime))
    • In reset condition select No reset condition – Trigger this alert each time the trigger condition is met:
    And leave other fields as default.
Reply
                   And the Message:
    NODES:
Children
No Data
