MACRO SQL ERROR when alert action repeats but not originally
I've got an issue where I have an alert sending a POST to a third party system for volume issues to create incidents, but I've had to do some SQL to escape the backslash in the volume name. It works fine when the alert triggers initially, but if I set it to repeat in 1 day if it is still active, the same statement throws a MACRO SQL ERROR.
Ideally we want to resend the POST in a day, to ensure that someone hasn't closed the alert in the other system but not resolved the actual problem. The retrigger will reopen the case but if the case is still open, the duplicate will be suppressed. This is preventing that behavior from being enabled.
Any thoughts on how to resolve this?
Statement in alert action configuration:
"description": " ${SQL: SELECT replace(Caption, '\', '\\') FROM Volumes WHERE VolumeID = ${VolumeID}} Percent ${N=SwisEntity;M=VolumePercentUsed} used"
Output when alert initially triggers:
"description": " H:\\ Label:New H Drive f4b7ee73 Percent 96 % used"
Output when alert triggers after 1 day:
"description": " MACRO SQL ERROR - Incorrect syntax near '{'. Percent 96 % used"
  • ${VolumeID} is a very old variable name and directly accessing variables this was has been deprecated.  All the new ones are in the format of ${N=;M=} (As you see in the Percent Used language).  It's also dependent on the alert type ("Alert on...").  That's why it's best to grab this from the Variable Picker and re-use it from there.
    I'm assuming you are packaging this up as a JSON to send this via HTTP to another system - is that correct?
  • Good catch. This was a carryover from a very old alert and we didn't update this one, and it was staring me right in the face. Seems strange that the original isn't impacted but the repeat is, but software does what software does.
    I'm testing it to be sure the original and repeat will work as expected now and will confirm in a day or so.
    And yes, this is packaging JSON to post to another system for incident generation. For volumes we found we needed to escape the backslash character when posting, and this was the most efficient method to do so.
  • A good option for escaping the characters.  I'm going to mark this question as "answered," but if it still doesn't work, please let me know and we can try some other things.
  • This does appear to have resolved the issue. Will continue to monitor, but we've retriggered and sent the POSTs off properly formatted with no errors. Thanks!!!
