I've read through the Incomplete guide, and tried to use the curl command they gave for a interface down alert, however it doesn't seem to work. Would anyone be able to give an example of the alert for interface down. Either using send to external program to use curl, or send a POST to webserver. Hoping to get one working example, then I can try reworking it for other alerts.
Example from pdf(I did edit path, channel, botname, and webhook url):
PATH _ TO _ CURL\bin\curl.exe -X POST --data-urlencode “payload={\”channel\”: \”#YOURCHANNEL\”, \”username\”: \”OrionBot\”, \”text\”: \”Alert - Interface: ${N=SwisEntity;M=Caption} status changed to ${N=SwisEntity;M=Status}\ nView: <${N=Alerting;M=AlertDetailsUrl}|Details>, <${N=SwisEntity;M=Node.DetailsUrl}|Node>\nTo acknowledge click <${N=Alerting;M=AcknowledgeUrl}|here>\”}”, https://YOUR _ SLACK _ WEBHOOK
