This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
Need assistance: Load snap-in when calling Powershell script in Advanced Alert
I recently found this great Poweshell script written by Paul Cunningham at http://exchangeserverpro.com/powershell-script-health-check-report-exchange-2010.  It generates an HTML report similar to the attached image.  I have modified this script to not display any screen output and to only send the email report.
The goal is to have an alert that when an Exchange issue is detected, either an Exchange server down or Exchange app monitor down/critical, to generate the report and send it out.  Now the script works on the Orion server from the command prompt or Powershell using the same credentials as Orion uses.   But when it is run from an advanced alert, it sends an email with no information.
From my troubleshooting, I have determined that the script is not loading the Exchange 2010 snap-in.   That command is generating an error of "No snap-ins have been registered for Windows PowerShell version 2"   I tried having the alert call it by running:
     c:\windows\system32\WindowsPowerShell\v1.0\Powershell.exe -version 2 -nologo -noprofile -command "C:\Scripts\ExchangeServerHealth\Test-ExchangeServerHealthMail.ps1"
and
     c:\windows\syswow64\WindowsPowerShell\v1.0\Powershell.exe -version 2 -nologo -noprofile -command "C:\Scripts\ExchangeServerHealth\Test-ExchangeServerHealthMail.ps1"
Both get the same result.
The server is running Windows Server 2008 R2 with SAM 5.5 and NPM 10.5.   The Exchange 2010 SP3 Managment Tools are installed on the server.
Does anyone have any ideas/suggestions?  Or is this not possible?
Below is copy of my modified version of Paul's script.
#requires -version 2
.SYNOPSIS
Test-ExchangeServerHealth.ps1 - Exchange Server 2010 Health Check Script.
.DESCRIPTION
Performs a series of health checks on the specified Exchange servers
and outputs the results to HTML email.
.LINK
.NOTES
Written By: Paul Cunningham
Website: http://exchangeserverpro.com
Twitter: http://twitter.com/exchservpro
Change Log
V1.0, 5/07/2012 - Initial version
V1.1, 5/08/2012 - Minor bug fixes and removed Edge Tranport checks
V1.2, 5/5/2013 - A lot of bug fixes, updated SMTP to use Send-MailMessage, added DAG health check.
V1.3, 8/7/2013 - Modified script to remove all parameter options, and writes to console and send via email only
# Variables
$now = Get-Date           #Used for timestamps
$date = $now.ToShortDateString()      #Short date format for email message subject
[array]$exchangeservers = @()       #Array for the Exchange server or servers to check
[int]$transportqueuehigh = 100       #Change this to set transport queue high threshold
[int]$transportqueuewarn = 80       #Change this to set transport queue warning threshold
$mapitimeout = 10          #Timeout for each MAPI connectivity test, in seconds
$pass = "Green"
$warn = "Yellow"
$fail = "Red"
$ip = $null
[array]$summaryreport = @()
[array]$report = @()
[bool]$alerts = $false
[array]$dags = @()          #Array for DAG health check
[int]$replqueuewarning = 8        #Threshold to consider a replication queue unhealthy
$dagreportbody = $null
# Modify these Email Settings
$smtpsettings = @{
To =  "something@domain.com
From = "something@domain.com"
Subject = "Exchange Server Health Report - $now"
SmtpServer = "smtpserver.something.com"
# Error/Warning Strings
$string0 = "Server is not an Exchange server. "
$string1 = "Server is not reachable. "
$string3 = "------ Checking"
$string4 = "Could not test service health. "
$string5 = "required services not running. "
$string6 = "Could not check queue. "
$string7 = "Public Folder database not mounted. "
$string8 = "Skipping Edge Transport server. "
$string9 = "Mailbox databases not mounted. "
$string10 = "MAPI tests failed. "
$string11 = "Mail flow test failed. "
$string12 = "No Exchange Server 2003 checks performed. "
$string13 = "Server not found in DNS. "
$string14 = "Sending email. "
$string15 = "Done."
$string16 = "------ Finishing"
$string17 = "Unable to retrieve uptime. "
$string18 = "Ping failed. "
$string19 = "No alerts found, and AlertsOnly switch was used. No email sent. "
# Initialize
Send-MailMessage @smtpsettings -Body "Plug-in Before" -BodyAsHtml -Encoding ([System.Text.Encoding]::UTF8) # Used for troubleshooting script
#Add Exchange 2010 snapin
Add-PSSnapin Microsoft.Exchange.Management.PowerShell.E2010
. $env:ExchangeInstallPath\bin\RemoteExchange.ps1
Connect-ExchangeServer -auto -AllowClobber
Send-MailMessage @smtpsettings -Body "Plug-in After" -BodyAsHtml -Encoding ([System.Text.Encoding]::UTF8) # Used for troubleshooting script
#Set recipient scope
if (!(Get-ADServerSettings).ViewEntireForest)
Set-ADServerSettings -ViewEntireForest $true -WarningAction SilentlyContinue
# Script
$tmpservers = @(Get-ExchangeServer | sort site,name)
foreach ($tmpserver in $tmpservers)
$exchangeservers = $exchangeservers += $tmpserver.identity
#Begin the health checks
foreach ($server in $exchangeservers)
#Find out some details about the server
$serverinfo = Get-ExchangeServer $server
#Custom object properties
$serverObj = New-Object PSObject
$serverObj | Add-Member NoteProperty -Name "Server" -Value $server
$site = ($serverinfo.site.ToString()).Split("/")
$serverObj | Add-Member NoteProperty -Name "Site" -Value $site[-1]
$serverObj | Add-Member NoteProperty -Name "DNS" -Value $null
$serverObj | Add-Member NoteProperty -Name "Ping" -Value $null
$serverObj | Add-Member NoteProperty -Name "Uptime (hrs)" -Value $null
$serverObj | Add-Member NoteProperty -Name "Version" -Value $null
$serverObj | Add-Member NoteProperty -Name "Roles" -Value $null
$serverObj | Add-Member NoteProperty -Name "Client Access Server Role Services" -Value "n/a"
$serverObj | Add-Member NoteProperty -Name "Hub Transport Server Role Services" -Value "n/a"
$serverObj | Add-Member NoteProperty -Name "Mailbox Server Role Services" -Value "n/a"
$serverObj | Add-Member NoteProperty -Name "Unified Messaging Server Role Services" -Value "n/a"
$serverObj | Add-Member NoteProperty -Name "Transport Queue" -Value "n/a"
$serverObj | Add-Member NoteProperty -Name "Queue Length" -Value "n/a"
$serverObj | Add-Member NoteProperty -Name "PF DBs Mounted" -Value "n/a"
$serverObj | Add-Member NoteProperty -Name "MB DBs Mounted" -Value "n/a"
$serverObj | Add-Member NoteProperty -Name "Mail Flow Test" -Value "n/a"
$serverObj | Add-Member NoteProperty -Name "MAPI Test" -Value "n/a"
$serverObj | Add-Member NoteProperty -Name "Error Details" -Value ""
$serverObj | Add-Member NoteProperty -Name "Warning Details" -Value ""
#Check server name resolves in DNS
try
  $ip = @([System.Net.Dns]::GetHostByName($server).AddressList | Select-Object IPAddressToString -ExpandProperty IPAddressToString)
catch
  $ip = $null
finally {}
if ( $ip -ne $null )
  $serverObj | Add-Member NoteProperty -Name "DNS" -Value "Pass" -Force
  #Is server online
  $ping = $null
  $ping = Test-Connection $server -Quiet
  switch ($ping)
   $true { $serverObj | Add-Member NoteProperty -Name "Ping" -Value "Pass" -Force }
   default { $serverObj | Add-Member NoteProperty -Name "Ping" -Value "Fail" -Force; $serverObj | Add-Member NoteProperty -Name "Error Details" -Value ($($serverObj."Error Details") + $string18) -Force }
  #Uptime check, even if ping fails
  $uptime = $null
  $laststart = $null
  $laststart = [System.Management.ManagementDateTimeconverter]::ToDateTime((Get-WmiObject -Class Win32_OperatingSystem -computername $server).LastBootUpTime)
  if ($laststart -eq $null)
   [string]$uptime = $string17
   switch ($ping)
                $true { $serverObj | Add-Member NoteProperty -Name "Warning Details" -Value ($($serverObj."Warning Details") + $string17) -Force }
    default { $serverObj | Add-Member NoteProperty -Name "Error Details" -Value ($($serverObj."Warning Details") + $string17) -Force }
  else
   [int]$uptime = (New-TimeSpan $laststart $now).TotalHours
   [int]$uptime = "{0:N0}" -f $uptime
  $serverObj | Add-Member NoteProperty -Name "Uptime (hrs)" -Value $uptime -Force
  if ($ping -or ($uptime -ne $string17))
   #Determine the friendly version number
   $ExVer = $serverinfo.AdminDisplayVersion
   if ($ExVer -like "Version 6.*")
    $version = "Exchange 2003"
   if ($ExVer -like "Version 8.*")
    $version = "Exchange 2007"
   if ($ExVer -like "Version 14.*")
    $version = "Exchange 2010"
   $serverObj | Add-Member NoteProperty -Name "Version" -Value $version -Force
   if ($version -eq "Exchange 2003")
    $report = $report + $serverObj
   #START - Exchange 2007/2010 Health Checks
   if ($version -eq "Exchange 2007" -or $version -eq "Exchange 2010")
    $serverObj | Add-Member NoteProperty -Name "Roles" -Value $serverinfo.ServerRole -Force
    $IsEdge = $serverinfo.IsEdgeServer
    $IsHub = $serverinfo.IsHubTransportServer
    $IsCAS = $serverinfo.IsClientAccessServer
    $IsMB = $serverinfo.IsMailboxServer
    #START - General Server Health Check
    #Skipping Edge Transports for the general health check, as firewalls usually get
    #in the way. If you want to include then, remove this If.
    if ($IsEdge -ne $true)
     #Service health is an array due to how multi-role servers return Test-ServiceHealth status
     $servicehealth = @()
     try {
      $servicehealth = @(Test-ServiceHealth $server)
     catch {
      $serverObj | Add-Member NoteProperty -Name "Warning Details" -Value ($($serverObj."Warning Details") + $string4) -Force
      $serverObj | Add-Member NoteProperty -Name "Client Access Server Role Services" -Value $string4 -Force
      $serverObj | Add-Member NoteProperty -Name "Hub Transport Server Role Services" -Value $string4 -Force
      $serverObj | Add-Member NoteProperty -Name "Mailbox Server Role Services" -Value $string4 -Force
      $serverObj | Add-Member NoteProperty -Name "Unified Messaging Server Role Services" -Value $string4 -Force
     if ($servicehealth)
      foreach($s in $servicehealth)
       $roleName = $s.Role
       switch ($s.RequiredServicesRunning)
        $true { $svchealth = "Pass" }
        $false {$svchealth = "Fail"; $serverObj | Add-Member NoteProperty -Name "Error Details" -Value ($($serverObj."Error Details") + ("$roleName $string5")) -Force }
        default {$svchealth = "Warn"; $serverObj | Add-Member NoteProperty -Name "Error Details" -Value ($($serverObj."Error Details") + ("$roleName $string5")) -Force }
       switch ($s.Role)
        "Client Access Server Role" { $serverinfoservices = "Client Access Server Role Services" }
        "Hub Transport Server Role" { $serverinfoservices = "Hub Transport Server Role Services" }
        "Mailbox Server Role" { $serverinfoservices = "Mailbox Server Role Services" }
        "Unified Messaging Server Role" { $serverinfoservices = "Unified Messaging Server Role Services" }
       $serverObj | Add-Member NoteProperty -Name $serverinfoservices -Value $svchealth -Force
    #END - General Server Health Check
    #START - Hub Transport Server Check
    if ($IsHub)
     $q = $null
     try {
      $q = Get-Queue -server $server
     catch {
      $serverObj | Add-Member NoteProperty -Name "Warning Details" -Value ($($serverObj."Warning Details") + $string6) -Force
     if ($q)
      $qcount = $q | Measure-Object MessageCount -Sum
      [int]$qlength = $qcount.sum
      $serverObj | Add-Member NoteProperty -Name "Queue Length" -Value $qlength -Force
      if ($qlength -le $transportqueuewarn)
       $serverObj | Add-Member NoteProperty -Name "Transport Queue" -Value "Pass" -Force
      elseif ($qlength -gt $transportqueuewarn -and $qlength -lt $transportqueuehigh)
       $serverObj | Add-Member NoteProperty -Name "Transport Queue" -Value "Warn" -Force
      else
       $serverObj | Add-Member NoteProperty -Name "Transport Queue" -Value "Fail" -Force
     else
      $serverObj | Add-Member NoteProperty -Name "Transport Queue" -Value "Unknown" -Force
    #END - Hub Transport Server Check
    #START - Mailbox Server Check
    if ($IsMB)
     #Get the PF and MB databases
     [array]$pfdbs = @(Get-PublicFolderDatabase -server $server -status -WarningAction SilentlyContinue)
     [array]$mbdbs = @(Get-MailboxDatabase -server $server -status | Where {$_.Recovery -ne $true})
                    if ($version -eq "Exchange 2010")
         [array]$activedbs = @(Get-MailboxDatabase -server $server -status | Where {$_.MountedOnServer -eq ($serverinfo.fqdn)})
                    else
      [array]$activedbs = $mbdbs
     #START - Database Mount Check
     #Check public folder databases
     if ($pfdbs.count -gt 0)
      [string]$pfdbstatus = "Pass"
      [array]$alertdbs = @()
      foreach ($db in $pfdbs)
       if (($db.mounted) -ne $true)
        $pfdbstatus = "Fail"
        $alertdbs += $db.name
      $serverObj | Add-Member NoteProperty -Name "PF DBs Mounted" -Value $pfdbstatus -Force
      if ($alertdbs.count -eq 0)
       #DO NOTHING
      else
       $serverObj | Add-Member NoteProperty -Name "Error Details" -Value ($($serverObj."Error Details") + $string7) -Force
     #Check mailbox databases
     if ($mbdbs.count -gt 0)
      [string]$mbdbstatus = "Pass"
      foreach ($db in $mbdbs)
        $mbdbstatus = "Fail"
      $serverObj | Add-Member NoteProperty -Name "MB DBs Mounted" -Value $mbdbstatus -Force
       #DO NOTHING
      else
       $serverObj | Add-Member NoteProperty -Name "Error Details" -Value ($($serverObj."Error Details") + $string9) -Force
     #END - Database Mount Check
     #START - MAPI Connectivity Test
     if ($activedbs.count -gt 0 -or $pfdbs.count -gt 0 -or $version -eq "Exchange 2007")
       $mapistatus = Test-MapiConnectivity -Database $db.Identity -PerConnectionTimeout $mapitimeout
       if ($mapistatus.Result.Value -eq $null)
        $mapiresult = $mapistatus.Result
                            else
        $mapiresult = $mapistatus.Result.Value
                            if (($mapiresult) -ne "Success")
      $serverObj | Add-Member NoteProperty -Name "MAPI Test" -Value $mbdbstatus -Force
       #DO NOTHING
      else
       $serverObj | Add-Member NoteProperty -Name "Error Details" -Value ($($serverObj."Error Details") + $string10) -Force
     #END - MAPI Connectivity Test
     #START - Mail Flow Test
     if ($activedbs.count -gt 0 -or ($version -eq "Exchange 2007" -and $mbdbs.count -gt 0))
      $flow = $null
      $testmailflowresult = $null
      try
       $flow = Test-Mailflow $server
      catch
       $testmailflowresult = $_.Exception.Message
      if ($flow)
       $testmailflowresult = $flow.testmailflowresult
      if ($testmailflowresult -eq "Success")
       $serverObj | Add-Member NoteProperty -Name "Mail Flow Test" -Value "Pass" -Force
      else
       $serverObj | Add-Member NoteProperty -Name "Error Details" -Value ($($serverObj."Error Details") + $string11) -Force
       $serverObj | Add-Member NoteProperty -Name "Mail Flow Test" -Value "Fail" -Force
     #END - Mail Flow Test
    #END - Mailbox Server Check
   #END - Exchange 2007/2010 Health Checks
  else
   #Server is not reachable and uptime could not be retrieved
   $serverObj | Add-Member NoteProperty -Name "Error Details" -Value ($($serverObj."Error Details") + $string1) -Force
else
  $serverObj | Add-Member NoteProperty -Name "Error Details" -Value ($($serverObj."Error Details") + $string13) -Force
  $serverObj | Add-Member NoteProperty -Name "DNS" -Value "Fail" -Force
### Begin DAG Health Report
$dags = @(Get-DatabaseAvailabilityGroup -Status)
if ($($dags.count) -gt 0)
foreach ($dag in $dags)
  #Strings for use in the HTML report/email
  $dagsummaryintro = "<p>Database Availability Group <strong>$($dag.Name)</strong> Health Summary:</p>"
  $dagdetailintro = "<p>Database Availability Group <strong>$($dag.Name)</strong> Health Details:</p>"
  $dagmemberintro = "<p>Database Availability Group <strong>$($dag.Name)</strong> Member Health:</p>"
  $dagdbcopyReport = @()  #Database copy health report
  $dagciReport = @()   #Content Index health report
  $dagmemberReport = @()  #DAG member server health report
  $dagdatabaseSummary = @() #Database health summary report
  $dagmembers = @($dag | Select-Object -ExpandProperty Servers | Sort-Object Name)
  $dagdatabases = @(Get-MailboxDatabase -Status | Where-Object {$_.MasterServerOrAvailabilityGroup -eq $dag.Name} | Sort-Object Name)
  foreach ($database in $dagdatabases)
   #Custom object for Database
   $objectHash = @{
    "Database" = $database.Identity
    "Mounted on" = "Unknown"
    "Preference" = $null
    "Total Copies" = $null
    "Healthy Copies" = $null
    "Unhealthy Copies" = $null
    "Healthy Queues" = $null
    "Unhealthy Queues" = $null
    "Lagged Queues" = $null
    "Healthy Indexes" = $null
    "Unhealthy Indexes" = $null
   $databaseObj = New-Object PSObject -Property $objectHash
   $dbcopystatus = @($database | Get-MailboxDatabaseCopyStatus)
   foreach ($dbcopy in $dbcopystatus)
    #Custom object for DB copy
    $objectHash = @{
     "Database Copy" = $dbcopy.Identity
     "Database Name" = $dbcopy.DatabaseName
     "Mailbox Server" = $null
     "Activation Preference" = $null
     "Status" = $null
     "Copy Queue" = $null
     "Replay Queue" = $null
     "Replay Lagged" = $null
     "Truncation Lagged" = $null
     "Content Index" = $null
    $dbcopyObj = New-Object PSObject -Property $objectHash
    $mailboxserver = $dbcopy.MailboxServer
    $pref = ($database | Select-Object -ExpandProperty ActivationPreference | Where-Object {$_.Key -eq $mailboxserver}).Value
    $copystatus = $dbcopy.Status
    [int]$copyqueuelength = $dbcopy.CopyQueueLength
    [int]$replayqueuelength = $dbcopy.ReplayQueueLength
    $contentindexstate = $dbcopy.ContentIndexState
    #Checking whether this is a replay lagged copy
    $replaylagcopies = @($database | Select -ExpandProperty ReplayLagTimes | Where-Object {$_.Value -gt 0})
    if ($($replaylagcopies.count) -gt 0)
                 [bool]$replaylag = $false
                 foreach ($replaylagcopy in $replaylagcopies)
         if ($replaylagcopy.Key -eq $mailboxserver)
          [bool]$replaylag = $true
             else
    #Checking for truncation lagged copies
    $truncationlagcopies = @($database | Select -ExpandProperty TruncationLagTimes | Where-Object {$_.Value -gt 0})
    if ($($truncationlagcopies.count) -gt 0)
                 [bool]$truncatelag = $false
                 foreach ($truncationlagcopy in $truncationlagcopies)
         if ($truncationlagcopy.Key -eq $mailboxserver)
          [bool]$truncatelag = $true
             else
    $dbcopyObj | Add-Member NoteProperty -Name "Mailbox Server" -Value $mailboxserver -Force
    $dbcopyObj | Add-Member NoteProperty -Name "Activation Preference" -Value $pref -Force
    $dbcopyObj | Add-Member NoteProperty -Name "Status" -Value $copystatus -Force
    $dbcopyObj | Add-Member NoteProperty -Name "Copy Queue" -Value $copyqueuelength -Force
    $dbcopyObj | Add-Member NoteProperty -Name "Replay Queue" -Value $replayqueuelength -Force
    $dbcopyObj | Add-Member NoteProperty -Name "Replay Lagged" -Value $replaylag -Force
    $dbcopyObj | Add-Member NoteProperty -Name "Truncation Lagged" -Value $truncatelag -Force
    $dbcopyObj | Add-Member NoteProperty -Name "Content Index" -Value $contentindexstate -Force
    $dagdbcopyReport += $dbcopyObj
   $copies = @($dagdbcopyReport | Where-Object { ($_."Database Name" -eq $database) })
   $mountedOn = ($copies | Where-Object { ($_.Status -eq "Mounted") })."Mailbox Server"
   if ($mountedOn)
    $databaseObj | Add-Member NoteProperty -Name "Mounted on" -Value $mountedOn -Force
   $activationPref = ($copies | Where-Object { ($_.Status -eq "Mounted") })."Activation Preference"
   $databaseObj | Add-Member NoteProperty -Name "Preference" -Value $activationPref -Force
   $totalcopies = $copies.count
   $databaseObj | Add-Member NoteProperty -Name "Total Copies" -Value $totalcopies -Force
   $healthycopies = @($copies | Where-Object { (($_.Status -eq "Mounted") -or ($_.Status -eq "Healthy")) }).Count
   $databaseObj | Add-Member NoteProperty -Name "Healthy Copies" -Value $healthycopies -Force
   $unhealthycopies = @($copies | Where-Object { (($_.Status -ne "Mounted") -and ($_.Status -ne "Healthy")) }).Count
   $databaseObj | Add-Member NoteProperty -Name "Unhealthy Copies" -Value $unhealthycopies -Force
   $healthyqueues  = @($copies | Where-Object { (($_."Copy Queue" -lt $replqueuewarning) -and (($_."Replay Queue" -lt $replqueuewarning)) -and ($_."Replay Lagged" -eq $false)) }).Count
         $databaseObj | Add-Member NoteProperty -Name "Healthy Queues" -Value $healthyqueues -Force
   $unhealthyqueues = @($copies | Where-Object { (($_."Copy Queue" -ge $replqueuewarning) -or (($_."Replay Queue" -ge $replqueuewarning) -and ($_."Replay Lagged" -eq $false))) }).Count
   $databaseObj | Add-Member NoteProperty -Name "Unhealthy Queues" -Value $unhealthyqueues -Force
   $laggedqueues = @($copies | Where-Object { ($_."Replay Lagged" -eq $true) -or ($_."Truncation Lagged" -eq $true) }).Count
   $databaseObj | Add-Member NoteProperty -Name "Lagged Queues" -Value $laggedqueues -Force
   $healthyindexes = @($copies | Where-Object { ($_."Content Index" -eq "Healthy") }).Count
   $databaseObj | Add-Member NoteProperty -Name "Healthy Indexes" -Value $healthyindexes -Force
   $unhealthyindexes = @($copies | Where-Object { ($_."Content Index" -ne "Healthy") }).Count
   $databaseObj | Add-Member NoteProperty -Name "Unhealthy Indexes" -Value $unhealthyindexes -Force
   $dagdatabaseSummary += $databaseObj
  #Get Test-Replication Health results for each DAG member
  foreach ($dagmember in $dagmembers)
   $memberObj = New-Object PSObject
   $memberObj | Add-Member NoteProperty -Name "Server" -Value $($dagmember.Name)
   $replicationhealth = $dagmember | Invoke-Command {Test-ReplicationHealth}
   foreach ($healthitem in $replicationhealth)
    $memberObj | Add-Member NoteProperty -Name $($healthitem.Check) -Value $($healthitem.Result)
   $dagmemberReport += $memberObj
  #Roll the HTML
  ####Begin Summary Table HTML
  $dagdatabaseSummaryHtml = $null
  #Begin Summary table HTML header
  $htmltableheader = "<p>
      <table>
      <tr>
      <th>Database</th>
      <th>Mounted on</th>
      <th>Preference</th>
      <th>Total Copies</th>
      <th>Healthy Copies</th>
      <th>Unhealthy Copies</th>
      <th>Healthy Queues</th>
      <th>Unhealthy Queues</th>
      <th>Lagged Queues</th>
      <th>Healthy Indexes</th>
      <th>Unhealthy Indexes</th>
      </tr>"
  $dagdatabaseSummaryHtml += $htmltableheader
  #End Summary table HTML header
  #Begin Summary table HTML rows
  foreach ($line in $dagdatabaseSummary)
   $htmltablerow = "<tr>"
   $htmltablerow += "<td><strong>$($line.Database)</strong></td>"
   #Warn if mounted server is still unknown
   switch ($($line."Mounted on"))
    "Unknown" { $htmltablerow += "<td class=""warn"">$($line."Mounted on")</td>" }
    default { $htmltablerow += "<td>$($line."Mounted on")</td>" }
   #Warn if DB is mounted on a server that is not Activation Preference 1
   if ($($line.Preference) -gt 1)
    $htmltablerow += "<td class=""warn"">$($line.Preference)</td>"
   else
    $htmltablerow += "<td class=""pass"">$($line.Preference)</td>"
   $htmltablerow += "<td>$($line."Total Copies")</td>"
   #Show as info if health copies is 1 but total copies also 1,
            #Warn if healthy copies is 1, Fail if 0
   switch ($($line."Healthy Copies"))
    0 {$htmltablerow += "<td class=""fail"">$($line."Healthy Copies")</td>"}
    1 {
     if ($($line."Total Copies") -eq $($line."Healthy Copies"))
      $htmltablerow += "<td class=""info"">$($line."Healthy Copies")</td>"
     else
      $htmltablerow += "<td class=""warn"">$($line."Healthy Copies")</td>"
    default {$htmltablerow += "<td class=""pass"">$($line."Healthy Copies")</td>"}
   #Warn if unhealthy copies is 1, fail if more than 1
   switch ($($line."Unhealthy Copies"))
    0 { $htmltablerow += "<td class=""pass"">$($line."Unhealthy Copies")</td>" }
    1 { $htmltablerow += "<td class=""warn"">$($line."Unhealthy Copies")</td>" }
    default { $htmltablerow += "<td class=""fail"">$($line."Unhealthy Copies")</td>" }
   #Warn if healthy queues + lagged queues is less than total copies
   #Fail if no healthy queues
   if ($($line."Total Copies") -eq ($($line."Healthy Queues") + $($line."Lagged Queues")))
    $htmltablerow += "<td class=""pass"">$($line."Healthy Queues")</td>"
   else
    switch ($($line."Healthy Queues"))
     0 { $htmltablerow += "<td class=""fail"">$($line."Healthy Queues")</td>" }
     default { $htmltablerow += "<td class=""warn"">$($line."Healthy Queues")</td>" }
   #Fail if unhealthy queues = total queues
   #Warn if more than one unhealthy queue
   if ($($line."Total Queues") -eq $($line."Unhealthy Queues"))
    $htmltablerow += "<td class=""fail"">$($line."Unhealthy Queues")</td>"
   else
    switch ($($line."Unhealthy Queues"))
     0 { $htmltablerow += "<td class=""pass"">$($line."Unhealthy Queues")</td>" }
     default { $htmltablerow += "<td class=""warn"">$($line."Unhealthy Queues")</td>" }
   #Info for lagged queues
   switch ($($line."Lagged Queues"))
    0 { $htmltablerow += "<td>$($line."Lagged Queues")</td>" }
    default { $htmltablerow += "<td class=""info"">$($line."Lagged Queues")</td>" }
   #Pass if healthy indexes = total copies
   #Warn if healthy indexes less than total copies
   #Fail if healthy indexes = 0
   if ($($line."Total Copies") -eq $($line."Healthy Indexes"))
    $htmltablerow += "<td class=""pass"">$($line."Healthy Indexes")</td>"
   else
    switch ($($line."Healthy Indexes"))
     0 { $htmltablerow += "<td class=""fail"">$($line."Healthy Indexes")</td>" }
     default { $htmltablerow += "<td class=""warn"">$($line."Healthy Indexes")</td>" }
   #Fail if unhealthy indexes = total copies
   #Warn if unhealthy indexes 1 or more
   #Pass if unhealthy indexes = 0
   if ($($line."Total Copies") -eq $($line."Unhealthy Indexes"))
    $htmltablerow += "<td class=""fail"">$($line."Unhealthy Indexes")</td>"
   else
    switch ($($line."Unhealthy Indexes"))
     0 { $htmltablerow += "<td class=""pass"">$($line."Unhealthy Indexes")</td>" }
     default { $htmltablerow += "<td class=""warn"">$($line."Unhealthy Indexes")</td>" }
   $htmltablerow += "</tr>"
   $dagdatabaseSummaryHtml += $htmltablerow
  $dagdatabaseSummaryHtml += "</table>
        </p>"
  #End Summary table HTML rows
  ####End Summary Table HTML
  ####Begin Detail Table HTML
  $databasedetailsHtml = $null
  #Begin Detail table HTML header
      <table>
      <tr>
      <th>Database Copy</th>
      <th>Database Name</th>
      <th>Mailbox Server</th>
      <th>Activation Preference</th>
      <th>Status</th>
      <th>Copy Queue</th>
      <th>Replay Queue</th>
      <th>Replay Lagged</th>
      <th>Truncation Lagged</th>
      <th>Content Index</th>
      </tr>"
  $databasedetailsHtml += $htmltableheader
  #End Detail table HTML header
  #Begin Detail table HTML rows
  foreach ($line in $dagdbcopyReport)
   $htmltablerow += "<td><strong>$($line."Database Copy")</strong></td>"
   $htmltablerow += "<td>$($line."Database Name")</td>"
   $htmltablerow += "<td>$($line."Mailbox Server")</td>"
   $htmltablerow += "<td>$($line."Activation Preference")</td>"
   Switch ($($line."Status"))
    "Healthy" { $htmltablerow += "<td class=""pass"">$($line."Status")</td>" }
    "Mounted" { $htmltablerow += "<td class=""pass"">$($line."Status")</td>" }
    "Failed" { $htmltablerow += "<td class=""fail"">$($line."Status")</td>" }
    "FailedAndSuspended" { $htmltablerow += "<td class=""fail"">$($line."Status")</td>" }
    "ServiceDown" { $htmltablerow += "<td class=""fail"">$($line."Status")</td>" }
    "Dismounted" { $htmltablerow += "<td class=""fail"">$($line."Status")</td>" }
    default { $htmltablerow += "<td class=""warn"">$($line."Status")</td>" }
   if ($($line."Copy Queue") -lt $replqueuewarning)
    $htmltablerow += "<td class=""pass"">$($line."Copy Queue")</td>"
   else
    $htmltablerow += "<td class=""warn"">$($line."Copy Queue")</td>"
   if (($($line."Replay Queue") -lt $replqueuewarning) -or ($($line."Replay Lagged") -eq $true))
    $htmltablerow += "<td class=""pass"">$($line."Replay Queue")</td>"
   else
    $htmltablerow += "<td class=""warn"">$($line."Replay Queue")</td>"
   Switch ($($line."Replay Lagged"))
    $true { $htmltablerow += "<td class=""info"">$($line."Replay Lagged")</td>" }
    default { $htmltablerow += "<td>$($line."Replay Lagged")</td>" }
   Switch ($($line."Truncation Lagged"))
    $true { $htmltablerow += "<td class=""info"">$($line."Truncation Lagged")</td>" }
    default { $htmltablerow += "<td>$($line."Truncation Lagged")</td>" }
   Switch ($($line."Content Index"))
    "Healthy" { $htmltablerow += "<td class=""pass"">$($line."Content Index")</td>" }
    default { $htmltablerow += "<td class=""warn"">$($line."Content Index")</td>" }
   $databasedetailsHtml += $htmltablerow
  $databasedetailsHtml += "</table>
        </p>"
  #End Detail table HTML rows
  ####End Detail Table HTML
  ####Begin Member Table HTML
  $dagmemberHtml = $null
  #Begin Member table HTML header
       <table>
       <tr>
       <th>Server</th>
       <th>Cluster Service</th>
       <th>Replay Service</th>
       <th>Active Manager</th>
       <th>Tasks RPC Listener</th>
       <th>TCP Listener</th>
       <th>DAG Members Up</th>
       <th>Cluster Network</th>
       <th>Quorum Group</th>
       <th>File Share Quorum</th>
       <th>DB Copy Suspended</th>
       <th>DB Initializing</th>
       <th>DB Disconnected</th>
       <th>DB Log Copy Keeping Up</th>
       <th>DB Log Replay Keeping Up</th>
       </tr>"
  $dagmemberHtml += $htmltableheader
  #End Member table HTML header
  #Begin Member table HTML rows
  foreach ($line in $dagmemberReport)
   $htmltablerow += "<td><strong>$($line."Server")</strong></td>"
   Switch ($($line.ClusterService))
    $null { $htmltablerow += "<td>$($line.ClusterService)</td>" }
    "Passed" { $htmltablerow += "<td class=""pass"">$($line.ClusterService)</td>" }
    default { $htmltablerow += "<td class=""warn"">$($line.ClusterService)</td>" }
   Switch ($($line.ReplayService))
    $null { $htmltablerow += "<td>$($line.ReplayService)</td>" }
    "Passed" { $htmltablerow += "<td class=""pass"">$($line.ReplayService)</td>" }
    default { $htmltablerow += "<td class=""warn"">$($line.ReplayService)</td>" }
   Switch ($($line.ActiveManager))
    $null { $htmltablerow += "<td>$($line.ActiveManager)</td>" }
    "Passed" { $htmltablerow += "<td class=""pass"">$($line.ActiveManager)</td>" }
    default { $htmltablerow += "<td class=""warn"">$($line.ActiveManager)</td>" }
   Switch ($($line.TasksRPCListener))
    $null { $htmltablerow += "<td>$($line.TasksRPCListener)</td>" }
    "Passed" { $htmltablerow += "<td class=""pass"">$($line.TasksRPCListener)</td>" }
    default { $htmltablerow += "<td class=""warn"">$($line.TasksRPCListener)</td>" }
   Switch ($($line.TCPListener))
    $null { $htmltablerow += "<td>$($line.TCPListener)</td>" }
    "Passed" { $htmltablerow += "<td class=""pass"">$($line.TCPListener)</td>" }
    default { $htmltablerow += "<td class=""warn"">$($line.TCPListener)</td>" }
   Switch ($($line.DAGMembersUp))
    $null { $htmltablerow += "<td>$($line.DAGMembersUp)</td>" }
    "Passed" { $htmltablerow += "<td class=""pass"">$($line.DAGMembersUp)</td>" }
    default { $htmltablerow += "<td class=""warn"">$($line.DAGMembersUp)</td>" }
   Switch ($($line.ClusterNetwork))
    $null { $htmltablerow += "<td>$($line.ClusterNetwork)</td>" }
    "Passed" { $htmltablerow += "<td class=""pass"">$($line.ClusterNetwork)</td>" }
    default { $htmltablerow += "<td class=""warn"">$($line.ClusterNetwork)</td>" }
   Switch ($($line.QuorumGroup))
    $null { $htmltablerow += "<td>$($line.QuorumGroup)</td>" }
    "Passed" { $htmltablerow += "<td class=""pass"">$($line.QuorumGroup)</td>" }
    default { $htmltablerow += "<td class=""warn"">$($line.QuorumGroup)</td>" }
   Switch ($($line.FileShareQuorum))
    $null { $htmltablerow += "<td>n/a</td>" }
    "Passed" { $htmltablerow += "<td class=""pass"">$($line.FileShareQuorum)</td>" }
    default { $htmltablerow += "<td class=""warn"">$($line.FileShareQuorum)</td>" }
   Switch ($($line.DBCopySuspended))
    "Passed" { $htmltablerow += "<td class=""pass"">$($line.DBCopySuspended)</td>" }
    default { $htmltablerow += "<td class=""warn"">$($line.DBCopySuspended)</td>" }
   Switch ($($line.DBInitializing))
    "Passed" { $htmltablerow += "<td class=""pass"">$($line.DBInitializing)</td>" }
    default { $htmltablerow += "<td class=""warn"">$($line.DBInitializing)</td>" }
   Switch ($($line.DBDisconnected))
    "Passed" { $htmltablerow += "<td class=""pass"">$($line.DBDisconnected)</td>" }
    default { $htmltablerow += "<td class=""warn"">$($line.DBDisconnected)</td>" }
   Switch ($($line.DBLogCopyKeepingUp))
    "Passed" { $htmltablerow += "<td class=""pass"">$($line.DBLogCopyKeepingUp)</td>" }
    default { $htmltablerow += "<td class=""warn"">$($line.DBLogCopyKeepingUp)</td>" }
   Switch ($($line.DBLogReplayKeepingUp))
    "Passed" { $htmltablerow += "<td class=""pass"">$($line.DBLogReplayKeepingUp)</td>" }
    default { $htmltablerow += "<td class=""warn"">$($line.DBLogReplayKeepingUp)</td>" }
   $dagmemberHtml += $htmltablerow
  $dagmemberHtml += "</table>
  </p>"
  #Output the report objects to console, and optionally to email and HTML file
  #Forcing table format for console output due to issue with multiple output
  #objects that have different layouts
  $dagreporthtml = $dagsummaryintro + $dagdatabaseSummaryHtml + $dagdetailintro + $databasedetailsHtml + $dagmemberintro + $dagmemberHtml
  $dagreportbody += $dagreporthtml
###End DAG Health Report
#Generate the report
#Get report generation timestamp
$reportime = Get-Date
#Generate report summary
$summaryreport = $report | select Server,"Error Details","Warning Details" | Where {$_."Error Details" -ne "" -or $_."Warning Details" -ne ""}
#Create HTML Report
#Common HTML head and styles
$htmlhead="<html>
   <style>
   BODY{font-family: Arial; font-size: 8pt;}
   H1{font-size: 16px;}
   H2{font-size: 14px;}
   H3{font-size: 12px;}
   TABLE{border: 1px solid black; border-collapse: collapse; font-size: 8pt;}
   TH{border: 1px solid black; background: #dddddd; padding: 5px; color: #000000;}
   TD{border: 1px solid black; padding: 5px; }
   td.pass{background: #7FFF00;}
   td.warn{background: #FFE600;}
   td.fail{background: #FF0000; color: #ffffff;}
   </style>
   <body>
   <h1 align=""center"">Exchange Server Health Check Report</h1>
   <h3 align=""center"">Generated: $reportime</h3>"
if ($summaryreport)
$summaryhtml = "<h3>Exchange Server Health Check Summary</h3>
     <p>The following errors and warnings were detected.</p>
     <p>
     <table>
     <tr>
     <th>Server</th>
     <th>Errors</th>
     <th>Warnings</th>
     </tr>"
foreach ($reportline in $summaryreport)
     $htmltablerow += "<td>$($reportline.server)</td>"
     switch ($($reportline."Error Details"))
      "" { $htmltablerow += "<td>$($reportline."Error Details")</td>" }
      default { $htmltablerow += "<td class=""fail"">$($reportline."Error Details")</td>" }
     switch ($($reportline."Warning Details"))
      "" { $htmltablerow += "<td>$($reportline."Warning Details")</td>" }
      default { $htmltablerow += "<td class=""warn"">$($reportline."Warning Details")</td>" }
     $summaryhtml = $summaryhtml + $htmltablerow
$summaryhtml = $summaryhtml + "</table></p>"
$alerts = $true
else
     <p>No Exchange server health alerts or warnings.</p>"
$alerts = $false
#Exchange 2007/2010 Report Table Header
$htmltableheader = "<h3>Exchange Server 2007/2010 Health</h3>
     <p>
     <table>
     <tr>
     <th>Server</th>
     <th>Site</th>
     <th>Roles</th>
     <th>Version</th>
     <th>DNS</th>
     <th>Ping</th>
     <th>Uptime (hrs)</th>
     <th>Client Access Server Role Services</th>
     <th>Hub Transport Server Role Services</th>
     <th>Mailbox Server Role Services</th>
     <th>Unified Messaging Server Role Services</th>
     <th>Transport Queue</th>
     <th>PF DBs Mounted</th>
     <th>MB DBs Mounted</th>
     <th>MAPI Test</th>
     <th>Mail Flow Test</th>
     </tr>"
$htmltable = $htmltable + $htmltableheader
foreach ($reportline in $report)
$htmltablerow += "<td>$($reportline.site)</td>"
$htmltablerow += "<td>$($reportline.roles)</td>"
$htmltablerow += "<td>$($reportline.version)</td>"
switch ($($reportline.dns))
  "Pass" {$htmltablerow += "<td class=""pass"">$($reportline.dns)</td>"}
  "Fail" {$htmltablerow += "<td class=""fail"">$($reportline.dns)</td>"}
switch ($($reportline.ping))
  "Pass" {$htmltablerow += "<td class=""pass"">$($reportline.ping)</td>"}
  "Fail" {$htmltablerow += "<td class=""fail"">$($reportline.ping)</td>"}
if ($($reportline."uptime (hrs)") -eq "Access Denied")
  $htmltablerow += "<td class=""warn"">Access Denied</td>"
       elseif ($($reportline."uptime (hrs)") -eq $string17)
           $htmltablerow += "<td class=""warn"">$string17</td>"
else
  $hours = [int]$($reportline."uptime (hrs)")
  if ($hours -le 24)
   $htmltablerow += "<td class=""warn"">$hours</td>"
  else
   $htmltablerow += "<td class=""pass"">$hours</td>"
switch ($($reportline."Client Access Server Role Services"))
  "Pass" {$htmltablerow += "<td class=""pass"">$($reportline."Client Access Server Role Services")</td>"}
  "Warn" {$htmltablerow += "<td class=""warn"">$($reportline."Client Access Server Role Services")</td>"}
  "Access Denied" {$htmltablerow += "<td class=""warn"">$($reportline."Client Access Server Role Services")</td>"}
  "Fail" {$htmltablerow += "<td class=""fail"">$($reportline."Client Access Server Role Services")</td>"}
           "Could not test service health. " {$htmltablerow += "<td class=""warn"">$($reportline."Unified Messaging Server Role Services")</td>"}
  default {$htmltablerow += "<td>$($reportline."Client Access Server Role Services")</td>"}
switch ($($reportline."Hub Transport Server Role Services"))
  "Pass" {$htmltablerow += "<td class=""pass"">$($reportline."Hub Transport Server Role Services")</td>"}
  "Warn" {$htmltablerow += "<td class=""warn"">$($reportline."Hub Transport Server Role Services")</td>"}
  "Access Denied" {$htmltablerow += "<td class=""warn"">$($reportline."Hub Transport Server Role Services")</td>"}
  "Fail" {$htmltablerow += "<td class=""fail"">$($reportline."Hub Transport Server Role Services")</td>"}
  default {$htmltablerow += "<td>$($reportline."Hub Transport Server Role Services")</td>"}
switch ($($reportline."Mailbox Server Role Services"))
  "Pass" {$htmltablerow += "<td class=""pass"">$($reportline."Mailbox Server Role Services")</td>"}
  "Warn" {$htmltablerow += "<td class=""warn"">$($reportline."Mailbox Server Role Services")</td>"}
  "Access Denied" {$htmltablerow += "<td class=""warn"">$($reportline."Mailbox Server Role Services")</td>"}
  "Fail" {$htmltablerow += "<td class=""fail"">$($reportline."Mailbox Server Role Services")</td>"}
  default {$htmltablerow += "<td>$($reportline."Mailbox Server Role Services")</td>"}
switch ($($reportline."Unified Messaging Server Role Services"))
  "Pass" {$htmltablerow += "<td class=""pass"">$($reportline."Unified Messaging Server Role Services")</td>"}
  "Warn" {$htmltablerow += "<td class=""warn"">$($reportline."Unified Messaging Server Role Services")</td>"}
  "Access Denied" {$htmltablerow += "<td class=""warn"">$($reportline."Unified Messaging Server Role Services")</td>"}
  "Fail" {$htmltablerow += "<td class=""fail"">$($reportline."Unified Messaging Server Role Services")</td>"}
  default {$htmltablerow += "<td>$($reportline."Unified Messaging Server Role Services")</td>"}
switch ($($reportline."Transport Queue"))
  "Pass" {$htmltablerow += "<td class=""pass"">$($reportline."Transport Queue") ($($reportline."Queue Length"))</td>"}
  "Warn" {$htmltablerow += "<td class=""warn"">$($reportline."Transport Queue") ($($reportline."Queue Length"))</td>"}
  "Fail" {$htmltablerow += "<td class=""fail"">$($reportline."Transport Queue") ($($reportline."Queue Length"))</td>"}
  "Unknown" {$htmltablerow += "<td class=""warn"">$($reportline."Transport Queue")</td>"}
  default {$htmltablerow += "<td >$($reportline."Transport Queue")</td>"}
switch ($($reportline."PF DBs Mounted"))
  "Pass" {$htmltablerow += "<td class=""pass"">$($reportline."PF DBs Mounted")</td>"}
  "Fail" {$htmltablerow += "<td class=""fail"">$($reportline."PF DBs Mounted")</td>"}
  default {$htmltablerow += "<td>$($reportline."PF DBs Mounted")</td>"}
switch ($($reportline."MB DBs Mounted"))
  "Pass" {$htmltablerow += "<td class=""pass"">$($reportline."MB DBs Mounted")</td>"}
  "Fail" {$htmltablerow += "<td class=""fail"">$($reportline."MB DBs Mounted")</td>"}
  default {$htmltablerow += "<td>$($reportline."MB DBs Mounted")</td>"}
switch ($($reportline."MAPI Test"))
  "Pass" {$htmltablerow += "<td class=""pass"">$($reportline."MAPI Test")</td>"}
  "Fail" {$htmltablerow += "<td class=""fail"">$($reportline."MAPI Test")</td>"}
  default {$htmltablerow += "<td>$($reportline."MAPI Test")</td>"}
switch ($($reportline."Mail Flow Test"))
  "Pass" {$htmltablerow += "<td class=""pass"">$($reportline."Mail Flow Test")</td>"}
  "Fail" {$htmltablerow += "<td class=""fail"">$($reportline."Mail Flow Test")</td>"}
  default {$htmltablerow += "<td>$($reportline."Mail Flow Test")</td>"}
$htmltable = $htmltable + $htmltablerow
$htmltable = $htmltable + "</table></p>"
$htmltail = "</body>
   </html>"
$htmlreport = $htmlhead + $summaryhtml + $htmltable + $dagreportbody + $htmltail
Send-MailMessage @smtpsettings -Body $htmlreport -BodyAsHtml -Encoding ([System.Text.Encoding]::UTF8)
attachments.zip
  • Here is what I am thinking, and correct me if I am wrong.  Since I am using Exchange 2010 with MS Server 2008 R2, the snap in will only load in a 64 bit powershell.   I am willing to bet that the advanced alerts is calling the 32bit powershell somehow and that is why the snap-in is not loading.
    What does everyone think?   And if this is the case, does anyone know of any workaround?
  • Open a Powershell command prompt and enter
    That should give you a bit more of an error message.
  • If I open a normal Powershell command prompt and run that command, as I stated above, the snap-in loads fine.   I can load the Powershell script without issues from the Powershell command prompt.   I only have issues when I try to have an Advanced Alert run the powershell script via the Execute an external program option.
    The only way that I recreate a similar problem would be to try to load the snap-in from the x86 Powershell, which is to be expected as the server is running 2008R2 which means the Exchange mgmt console has to be 64-bit.
    I just did a test alert.   I had the execute a program just run cmd.exe.  Ran a test alert trigger.   Watched the processes in task manager.   When cmd.exe loaded, it was 32 bit.   So it appears that the advanced alert execute a program option only loads items in 32 bit mode.    Is there any way to force 64 bit?
  • Okay.  I figured out what needs to be done to get it to work.
    First, I needed to change the account for the SolarWinds Alerting Engine service from Local System to the AD service account that I use with Orion.
    Second, I need to bring up a 64 bit command prompt as Administrator.   Browse to C:\windows and run the command mklink powershell64.exe c:\windows\system32\windowspowershell\v1.0\powershell.exe.
    Once I did this, if I use powershell64.exe -command "Path of powershell script" in the Execute an external program, then the script loads the add-in successfully.
    The problem is that the Advanced Alerts is a 32bit process.  So even if you point to the path of a 64bit program, Windows runs it as a 32-bit process.  But if you use a symbolic link, you can invoke the 64bit process.
