Compare custom property to total capacity
This could be more generic across other modules, but I'm using it in SRM, hence putting it here.
I have added a custom property for each volume as a text string such as "500.00 GB" and am trying to compare it to volume's total capacity which if I look at the property also shows "500.00 GB". However, when I set an alert to check if two are equal, it doesn't trigger the alert even though they are equal.
Any ideas of how I can accomplish this?
  • I „think“ the amount is stored in Bytes rather than GB. At least for NPM this is the case.
    I also think you can’t compare a string value to an integer, that doesn’t make sense.
    For an alert I usually use a custom SWQL Query as this gives me more flexibility in comparing values. E.g. I can use GB in the Custom property and just convert the value to Byte in my SWQL-Query
  • That totally makes sense. I don't know why I lept thinking that it converts a total capacity value from integer to string, hence, I kept trying to compare what I thought was 2 strings. I see it now, though.
    Now, I just need to figure out how to compare the 2 using SWQL query.  , do you have an example for that?
  • This is for the NPM/SAM Volume Alerts, it should be translateable to SRM somehow. I don't have many SRM Clients currently....
    use an alert and alert on a Volume, the upper menu should populate automatically with the volume selection. In the lower selection something like this:
    JOIN Orion.VolumesCustomProperties vcp ON v.VolumeID = vcp.VolumeID
    JOIN Orion.Nodes nodes on v.NodeID = nodes.NodeID
    JOIN Orion.NodesCustomProperties ncp on nodes.NodeID = ncp.NodeID
    where v.VolumeSpaceAvailable >= vcp.YourCPNameforTheVolume
    Your CP should now be in "bytes" if you want it in GB you can use methematical operations like vcp.YourCPNameforTheVolume*1024 etc.
