I just installed SCM and applied the IIS out of the box profile to the Orion server itself. It pulled the configs and I set a baseline.
Overnight SCM triggered an alert on one of the web.config files due to a "false" becoming "False" (note case change).
Is there a way to control case sensitivity in the config comparison so the case sensitivity is manually managed or matches the OS default?
