Hi Guys,
Trying to use the above mentioned template but the following components error with the below
Failed Jobs
The return code is different than expected. Testing on node '127.0.0.1' failed with 'Down' status ('Down' might be different if script exits with a different exit code).
No snap-ins have been registered for Windows PowerShell version 5.
Job Status
PowerShell script error. Scripting Error: Script does not contain the expected parameters or is improperly formatted. 'Last_Job_Result', 'Job_State', 'Last_Session_Backup_Size', 'Last_Session_Compression_Ratio', 'Last_Session_Data_Size', 'Last_Session_Deduplication_Ratio' missing.
Any ideas? I've ensure the PowerShell module for Veam are present on the server being monitored and the SolarWinds server
