This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
Access denied using Powershell Monitor running Veeam Snap-In commands.
Hi Thwack
I'm relatively new to SAM so treat me as a newbie. I'm currently using the Veeam 9.5 template from Thwack (https://thwack.solarwinds.com/product-forums/server-application-monitor-sam/f/forum/24569/veeam-backup-and-replication-management-server-v9-5-apm-template/290585#290585)
In here is a "Failed Jobs" Powershell command, that after following KB (https://support.solarwinds.com/SuccessCenter/s/article/SAM-template-Veeam-Backup-and-Replication-Server-not-working-correctly?language=en_US) to get working with Veeam 11. We are just getting the following message:
Output: ==============================================
Message: ERROR executing "Get-VBRJob": Access is denied
Message: No failed backup or replication jobs found.
Statistic: 0
Veeam PS snap-in is installed and loaded to use on the VBR server on the "Credential for Monitoring" account. I'm using Execution = Remote Host so the commands run on the VBR server not from SolarWinds server and still getting access denied (that account is also full admin on Veeam).
If I run the script locally it works fine, but I'm struggling to even start diagnosing where the issue lies.
Is there any help anyone could give me.
Many thanks
Graham
