This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
SAM Monitor Node Export
Apologies if this has been answered in a separate thread, I'm not finding it if there's one.  I have several hundred nodes assigned to an application monitor and I'm trying to export that list of nodes.  I've looked around and I'm not finding an export option.  I feel it's probably gonna be something easy but I'm not finding it.
Thanks for any help.
  • And I found how to export them.  I had already added a widget to one of my dashboard and I just have to bring up that page and I was able to just copy/paste the entire page and futz with it in XLS.  I'm thinking there's a way to run an SQL query but who has time.  Slight smile
  • If you would like to use SWQL below query will list all nodes that has a specific application assigned to it:
    ('WebTest' is the name of the application we are looking for in these examples. Change to what you need to look for.)
    SELECT
        A.Name AS [Application]
        ,A.Node.Caption AS [Server Name]
    FROM Orion.APM.Application AS A
    WHERE
        A.Name='WebTest'
    If you are more into SQL, this is the code for you:
    SELECT
    	,N.Caption AS [Server Name]
    FROM APM_Application AS A
    INNER JOIN NodesData as N ON A.NodeID=N.NodeID
    WHERE
    	A.Name='WebTest'
  • Hey Seashore, thanks for the response, I'll give it a go and report back.
