Monitoring a service with whitespace
Using SAM to monitor various things, however I've run across an issue monitoring a service name with whitespace. I searched around and found some issues with logs and whitespace. Is there something that can be done to do this? On one server an easy work-around was to just monitor the process, however the server in question has multiple services using a wrapper command that looks similar to Orion, so it cannot differentiate between the four same processes, even though they're technically different.
