Shared Drive monitoring for a Clustered Server Node
Hi All,
Not sure if u have come across this scenario.. we have some Windows servers which are Cluster nodes and they have some drives which are of shared nature... So it remains visible/owned only for the node which is active.. we are monitoring both members of the cluster separately but the shared drive will be available only for 1 node so Solarwinds will monitor only for 1 node and incase for that node, drive moves to other node then it shows down and not detected on the node to which the drive moved...
In this case, how can we monitor and ensure that drive is monitored even when failover of that server happens...as per our Windows SMEs this is very basic... so need some light on this if anyone is doing this or any alternate options
