Performance Counter Monitor - Bad Input Pameter - HResult
We are running 'Active Directory 2008 R2 Services and Counters' template on 10+ domain controllers and all report correctly except for one trouble server. The service monitors work correctly but the performance counter monitors are failing with the error: "Bad input parameter. HResult: The specified object is not found on the system."
I've searched around and tried the following fixes:
  • Restarting Remote Registry - http://thwack.solarwinds.com/message/169647#169647
  • Restarting WMI
  • Adding Network Service as COM Services Admin
  • Microsoft Remote Registry Hotfix - http://support.microsoft.com/kb/2699780
  • Checked license availability for application monitors
  • Rebooted Server
  • Tried to rebuild the performance counters
  • Ran Perfmon from the Solarwinds Server, managed the not working server and selected several counters from above that are not working via the web browser and they monitored correctly
  • I thought it might be a permissions issue but I ran PerfMon from a working DC and managed the not woring DC and it reported correctly. I tried this in reverse and it also worked correctly.
Our setup is:
     Orion Platform 2013.1.0, SAM 5.5.0, IPAM 4.0, NCM 7.2, NPM 10.5, NTA 3.11.0, IVIM 1.6.0, VNQM 4.0.1
  • This has been fixed/corrected. Thank you Kate @ Solarwinds!
    The issue is simply that the counter is not present on the problem server. The application monitor is polling for Category: NTDS.
    If you look at a working Domain Controller, the Counter is there:
    But on the not working server it is not there:
    For this server we had to override the template and change the counter to DirectoryServices:
    This is odd because both servers are Windows 2008 R2 SP1.  No differences that I know of.
    It appears the working servers have BOTH counter categories, DirectoryServices and NTDS where-as the not working server is missing NTDS.
    Thanks to all for the help!
  • Side note: I also had to add a instance of NTDS:
    You can find this in the Performance Monitor:
    Yours might be different.
  • Anytime!
    For anyone who might read this, I am 90% sure that this was caused because the Domain controller was promoted, demoted and then re-promoted to domain controller status.
    I noticed that the performance folder was missing from the registry on the not working domain controller but was there on a working domain controller.
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\NTDS\Performance
    I exported NTDS from the a working Domain Controller and imported.
    I tested and it work!
