Automatic Dependencies Based On Custom Properties (Node Location)
< BACK TO TO THE MAGIC OF SQL SCRIPTS SERIES LIST
Hi Guys,
I am very excited to present you with this solution that will allow you to create automatic dependencies based on custom properties. Again, this solution fits perfectly well with my previously discussed automation, such as Automatically Update World Map Points Based On Custom Property Value and Manage Node's Response Time Thresholds Better By Accounting For WAN Latencies. I suggest you skim read them first to get an idea of the structure and then carry on with this setup as I am going to be building this solution on top of existing config
So, let's begin...
How it will work:
You will maintain location information for your nodes in custom property ("n_site_id" for example).
You will have table, which will hold all information about your sites + information about edge devices (or group of edge devices if you have HA routers/firewall on the edge) allocated to every site.
You we will then have magic happening at the background which will keep creating and managing all site dependencies for you the moment you change site for the node or update edge devices for any site
Note: I do this just for the 1st level of PARENT-CHILD relationships. It will possibly work with more deeper levels, but requires further testing to ensure logic will work as expected. For our global architecture with 20+ sites (as below) this works perfectly fine
The result is pretty awesome. In my case 153 dependencies have been automatically created in a split of a second and now are being dynamically managed just by me maintaining node's site id custom property. Besides I really feel I am in full control over them all
Notice naming convention:
Names start with "auto_" for all dependencies created this way. In case you create some of your own manual dependencies they will not be overwritten nor will be deleted as long as you do not give your manually created dependencies "auto_" at the beginning of a name
Here is how it will look like on the Node's page when you will add resource "All Dependencies including node ${Caption}"
Step-by-step:
(1)
First, you need Aux database
(2)
Second, you need to have Sites table within this database as described here in step (2) + add additional two columns to define Edge device IDs
(3)
Third - you need "n_site_id" custom property which you will use to specify the location for the node. As described in my previous articles I do this with "n_site_id" custom property:
(4)
And finally, with all the above you are now ready to Rock'n Roll with scripted dependencies creation
Here is a magical two SQL scripts for you to do so.
This one is to create dependencies when parent is a Node:
MERGE SolarWinds.dbo.Dependencies AS Target
USING
    SELECT
      n.NodeID
     ,n.Caption
     ,n.n_site_id
     ,s.EdgeNodeID
     ,'auto_n'+CONVERT(NVARCHAR(250),s.EdgeNodeID)+'--n'+CONVERT(NVARCHAR(250),n.NodeID) AS 'DependencyName'
     ,'swis://XXXXXXXXXXXXXXXXXXXXX/Orion/Orion.Nodes/NodeID='+CONVERT(NVARCHAR(250),s.EdgeNodeID) AS 'ParentUri'
     ,'swis://XXXXXXXXXXXXXXXXXXXXX/Orion/Orion.Nodes/NodeID='+CONVERT(NVARCHAR(250),n.NodeID) AS 'ChildUri'
    FROM SolarWinds.dbo.Nodes n
    LEFT JOIN SolarWindsAux.dbo.Sites s ON s.SiteID=n.n_site_id
    LEFT JOIN Solarwinds.dbo.Dependencies d ON (d.ChildUri LIKE '%='+CONVERT(NVARCHAR(250),n.NodeID) AND d.Name LIKE 'auto_n%')
  ) AS Source (nNodeID, nCaption, nSiteID, sEdgeNodeID, nDependencyName, nParentUri, nChildUri) ON (Target.ChildUri = Source.nChildUri AND Target.Name = Source.nDependencyName)
-- Delete from DEPENDENCIES...
WHEN NOT MATCHED BY source --if node no longer exist in Nodes table...
  AND Target.Name LIKE 'auto_n%' --and providing that record has been created by this automation
THEN DELETE
WHEN MATCHED --if record already exist...
  AND (
  Source.nSiteID IS NULL --and either site id was not specified
  OR Source.sEdgeNodeID IS NULL --or edge device was not specified for this site
  OR Source.nNodeID = Source.sEdgeNodeID --or device is an edge device itself
THEN DELETE
-- Update record if...
WHEN MATCHED --record exist...
  AND Source.nParentUri <> Target.ParentUri --and if edge device has been changed (this can be due to site for the node has been changed or edge itself has been changed for the entire site)
THEN UPDATE
  SET
   Name = nDependencyName,
   ParentUri = nParentUri,
   LastUpdateUtc = GetUtcDate()
-- Synch new dependencies
WHEN NOT MATCHED BY target
  AND Source.nSiteID IS NOT NULL --Site has been specified
  AND Source.sEdgeNodeID IS NOT NULL --Edge device has been specified
  AND Source.nNodeID <> Source.sEdgeNodeID --Node is not edge device itself
THEN
  INSERT (Name, ParentUri, ChildUri, LastUpdateUtc)
  VALUES (nDependencyName, nParentUri, nChildUri, GetUtcDate())
This one is to create dependencies when parent is a Group:
USING
    SELECT
      n.NodeID
     ,n.Caption
     ,n.n_site_id
     ,s.EdgeGroupID
     ,'auto_g'+CONVERT(NVARCHAR(250),s.EdgeGroupID)+'--n'+CONVERT(NVARCHAR(250),n.NodeID) AS 'DependencyName'
     ,'swis://XXXXXXXXXXXXXXXXXXXXXX/Orion/Orion.Groups/ContainerID='+CONVERT(NVARCHAR(250),s.EdgeGroupID) AS 'ParentUri'
     ,'swis://XXXXXXXXXXXXXXXXXXXXXX/Orion/Orion.Nodes/NodeID='+CONVERT(NVARCHAR(250),n.NodeID) AS 'ChildUri'
    LEFT JOIN Solarwinds.dbo.Dependencies d ON (d.ChildUri LIKE '%='+CONVERT(NVARCHAR(250),n.NodeID) AND d.Name LIKE 'auto_g%')
  ) AS Source (nNodeID, nCaption, nSiteID, sEdgeGroupID, gDependencyName, nParentUri, nChildUri) ON (Target.ChildUri = Source.nChildUri AND Target.Name = Source.gDependencyName)
-- DELETE RECORD...
  AND Target.Name LIKE 'auto_g%' --and providing that record has been created by this automation
THEN DELETE
-- DELETE RECORD...
WHEN MATCHED --if node exist...
  AND (
  Source.nSiteID IS NULL --and either site was not specified
  OR Source.sEdgeGroupID IS NULL --or edge group was not specified for this site
  OR Source.nNodeID IN --or node is a member of the edge group itself
    (SELECT n_excl.EntityID
     FROM Solarwinds.dbo.ContainerMemberSnapshots n_excl
     WHERE
       n_excl.EntityType = 'Orion.Nodes' AND
       n_excl.ContainerID = Source.sEdgeGroupID))
THEN DELETE
-- UPDATE RECORD...
WHEN MATCHED --when it is already there...
  AND Target.Name LIKE 'auto_g%' --and providing that record has been created by this automation...
  AND Source.nParentUri <> Target.ParentUri --and edge group has been changed (this can be due to site for the node has been changed or edge group has been changed for the entire site)
THEN UPDATE
  SET
   Name = gDependencyName,
-- INSERT NEW RECORD...
WHEN NOT MATCHED BY target --when it does not already exist...
  AND Source.nSiteID IS NOT NULL --and site has been specified...
  AND Source.sEdgeGroupID IS NOT NULL --and edge group has been specified...
  AND Source.nNodeID NOT IN --and node is not a member of the Edge group itself
     WHERE
       n_excl.ContainerID = Source.sEdgegroupID)
THEN
  VALUES (gDependencyName, nParentUri, nChildUri, GetUtcDate())
IMPORTANT:
4.1 You first need to go though this script and change database name as per your SQL setup
4.2 You also need to replace 'XXXXXXXXXXXX' with correct FQDN for your environment. The best way to do so is to create dependency manually and then check ParentUri and ChildUri columns in [Dependencies] table to find out what it should be set to
(5)
Final step is to configure SQL job to do it automatically (unless you are ok to run the above scripts manually every time somebody changes site id for your nodes).
Please refer to the following step-by-step guide from MSDN on how to create SQL scheduled job: Schedule a Job
Maintenance:
You will need to populate your Sites table with data first.
  • SiteID column should have values corresponding with "n_site_id" custom properties drop down values.
  • EdgeNodeID is an ID of a node. When you land on the node page you can get this ID from the URL
  • EdgeGroupID is an ID of a group. Group your edge devices together and then from the group summary page note down Group ID from the URL
    • Remember to set your group settings to roll over to down state only when all devices are down (screenshot below) - this is key when setting up dependencies for the group
Here is an example of populated records in table:
Please note that you would normally specify either EdgeNodeID or EdgeGroupID for a specific site, not both of them at the same time
That's it.
From now on all you need to do is to allocate correct site ID for your nodes (or to change site ID for exisitng one) for the magic to happen emoticons_happy.png
Happy SolarWinding
Alex Soul
www.pixace.com
Top Replies
  • As a feature would be nice, but until then...
    In my testing environment, I used Custom_Aux, but if I can do this in live, I might use something more unique, like using my Dept initials (ITSD) to prefix the table.
  • Hi Alex, should this code work on NMP 12?
    I am creating dependencies, 711 of them, but they do not show in he manage decencies global or on the node.
    did you update this for V12?
    Cheers
    Mez
  • its ok think Ive got it working in V12
    INSERT (Name, ParentUri, ChildUri, LastUpdateUtc,ParentNetObjectID,ChildNetObjectID,ParentEntityType,ChildEntityType)
    VALUES (nDependencyName, nParentUri, nChildUri, GetUtcDate(), sEdgeNodeID,nNodeID,'Orion.Nodes','Orion.Nodes')
    I also dotn use a separate table, I have a view group on site code, and with our naming conventions pick out the router for that site. a lot easier not having to maintain a separate list. will see if I like the 711 dependencies now. thanks alot
  • nice one, good spot. Ye, I didn't get a chance to migrate this one to V12 yet and your input is highly appreciated emoticons_happy.png
  • oh Alex another question, can you explain a little more re logic in a HA scenario?
    rolling out a new wan, all sites will have a single router (no spoke sites anymore emoticons_wink.png) I have set dependencies using this script for all remote sites, so all hardware switches,firewalls etc are dependant on the remote site router - works like a charm now with the above tweaks.
    However all the new wan sites have two paths back to DC1 and DC2. I have currently removed the HA both routers from the data centres (sites) from my view to ensure I get the dependencies correct. Any help greatly appreciated.
    When I took the HA routers out my dependencies row count dropped to 488 ish
    Mez
  • just got back from a short break. Are you able to sketch basic diagram to make it bit more clear about the line-of-sight between SolarWinds poller and nodes from the wan perspective, including those two DCs
  • alexslv
    I just wanted to drop in and let you know about the NPM 12 bug with the script. I just implemented this to get rid of the rampant auto-dependencies that Solarwinds creates when you have it set to calculate automatically.
    Here are the last two lines of the script if you're using Groups for dependencies vs NodeID's:
    THEN
      INSERT (Name, ParentUri, ChildUri, LastUpdateUtc, ParentNetObjectID, ChildNetObjectID, ParentEntityType, ChildEntityType)
      VALUES (gDependencyName, nParentUri, nChildUri, GetUtcDate(), sEdgeGroupID, nNodeID, 'Orion.Groups', 'Orion.Nodes')
    I hope this helps some others as well. Thanks to mezdem​ for getting me to the point where the info was missing from the script!
  • Can we try this in 2019 version of Orion alexslv
    Please suggest as I am looking for solution where Priority 2 ticket will not get generated for nodes which has redundancy in place.
    We are getting bulk of P2 alerts and looking for solution to reduce it.
