We have a setup with many E2E environments.
In each environment there is an SFTP setup with AD integration (Serv-U 15.3.0.1356) and in each environment we have created many AD groups, which we then associate with the corresponding directory on the Serv-U server.
We have done this because there are many users who need to access several different directories. Setting this up is time consuming and there is the possibility of errors entering these many groups, and permissions out to the final directory.
I want to hear if it is possible to take the whole configuration and export to a csv file.
We have the same structure in the environments.
The csv file I will adapt and move to new environment and import to the new environment .. if possible?
I know you can copy Serv-U.Archive .. but editing that file does not immediately look easy ...
Thanks in advance!
