Multiple Virtual Host domains not working after applying 15.2.3 HotFix2
Since applying 15.2.3 HotFix2 when navigating to a domain using a virtual host I get routed back to the primary domain with the 443 listener
An example of my setup is:
domain1.com listener on port 443
domain2.com no listener, virtual host https://domain2.com
When I navigate to https://domain2.com the login page and browser tab is Domain1 Serv-U
Other than applying the HotFix nothing else has changed on the host running Serv-U
  • So a quick update, putting the 443 listeners on all domains appears to have allowed all domains to work again.
    This isn't the way it worked before and I worry that having a 443 per domain listener on the same IP address is bad config.
  • Thanks   I have this exact same issue, created virtual domains and shared the IP and Port and all was fine untill 150.2.3 HF2, and logged a case, Ill give this a go
    Cheers
