MFT LDAP Groups Question
If I have 2 AD Security Group, where I have Users assigned (some users are in Both Groups)
Some users in seperate groups
If I grant Access to a different Home Dir and Assign permission to different folder structure
does MFT application affectively only allow the users to view the more restrictive folder
Also does the MFT apply least restriction to those users in both groups
Example
I have a group that I make the Home Dir %DOMAIN-HOME% and Directory Access %DOMAIN_HOME% with RWADN-L---I
the 2nd Group Home Dir %DOMAIN-HOME%\Subfolder and Directory Access %DOMAIN_HOME%\Subfolder with RW-DN-L---I
Just wondering how MFT applies its rules for Home DIR and rights
  • FYI Found my Own Answer
    If you have a user with access to different directory structures under the same root then the user gets the Lower level applied to their connection
    So if the user has the following applied by 2 groups option 2 is presented to the user (note user can not browse up if "lock user in homeDirectory" is applied)
    1 Home Dir %DOMAIN-HOME%
    2 Home Dir %DOMAIN-HOME%\Subfolder
    Regarding File permissions
    If a user is a member of 2 groups where different file restrictions are applied, then the most restrictive setting appears to apply
    Hope this helps others when considering DIR and File restrictions
    Cheers
