I have just discovered NTM and i am wondering if when you export the discovered map to network atlas (not an option in the free trial) does the nodes automatically show up as live (up/down) status in solarwinds after i save the map? or do i have to drag n drop the nodes over to the map - like this export would be just a background?
Also, all the info from the NTM - is it available for viewing in solarwinds once exported to solarwinds?
Side note question, why would Orion Maps not have an option to discover all nodes or a group of nodes for one map instead of someone having to drag and drop them on a map...and when that someone does that why would the Port Channels not show up correctly if they have that working in NTM?
