Netflow data utilization report
Hi All,
I need to create a report for the Netflow data, that will show me the amount of data passed between source and destination, for example, the amount of data (in bytes) passed between an IP in the organization and the mail server in the last 7 days or 24 hours, or any IP to any application. I did not find something like that in the reports, or I missed it if it is there.
  • Hello there,
    You should be able to achieve this using a custom table or chart with a datasource like this:
    The above example shows traffic between our SCCM server and a particular device on the network.
    Let me know if you have any questions.
    Kind regards, Marlie.
    If this helps you please mark my response as the answer to help other members in future.
