I'm trying to create an Orion map (not a legacy Network Atlas map) that has logos for applications overlaid with a group status icon. I created a map on ComputerA last week, and when I view the map from ComputerA I can see both the image and the group status overlay (green circle with check box). When I view the map on ComputerB, or other users view the map, we're only getting the group status icon without the custom image behind it. There isn't a broken image icon though, like the file can't be found, there's just a blank spot. When I inspect the map with the browser dev tools on ComputerB, I can see 500 errors for the images coming from myserver/api2/Maps/v1/Assets/Images/7bd79c2d-c3bc-45b1-b02d-34b629fe12e7.png/
Do the new Orion Maps require you to upload custom images directly to the web server? If so, does anyone know where they're supposed to go?
