BLANK PDF ON EMAILED REPORTS
We have several reports that export a chart to a PDF and get emailed on a schedule. The email comes across fine but the PDF chart does not show up. We are on the latest software updates. I have not found a permanent fix for this. Anyone out there have any suggestions?
Parents
  • I am also experiencing this issue after our recent upgrade to 2020.2.4
    Have you found any resolution to this?
  • It's probably polling incorrect data. After I upgraded to 2020.2.x I had to go back and fix reports as it was trying to pull something that didn't exist. I can't recall what fixed my issue but I know I had to go back and adjust some parameters.
    Make sure to go through the schedule as well as the report to ensure there is nothing incorrect such as the user running the report is valid or that the report is pulling the correct fields
Reply
Children
No Data
