Execute external Python script from NPM
I'm new with Python but succeeded to write Python script with tk (python with GUI),
I want to install Python on my Orion server (windows) and execute the script from NPM, i saw that I can run external script from alert action and with SAM but this is not the case
This script open GUI window with embedded juniper show commands, and I what to be able to run this from NPM the same way i can open SSH or Https to the device from orion node
Is it possible ?
Regards
Rafi
  • What are you attempting to accomplish with this script?
    Is this in response to an event or just a periodic check of values?
    In what form is the output?
    Do you do anything with the output?
  • The goal is to create button on NPN summery node, and from there run the scripn
    It should not be response to an event,
    The scenario is when i open the npm summery and i want to run some show command i will be able to execute the python (which will be located on orion server) script from the npm summery screen, same way i can do SSH or Https from npm
