Schedule Unmanaged Utility
Just curious if anyone has had any luck in getting this utility to work?  Is there any documentation that can help someone trying to get it work?  I have been trying to get this to work for a while now and I am stumped...  I have the utility it has made a .cmd file....  OK now what?  What I see on my screen and what is described in the help files that came with the utility are not even close.
As an example... the wizard explains that after adding a node in the create new task we need to open a program called 'Add scheduled Task'
All Programs > Accessories > System Tools > Scheduled Tasks > Add Scheduled Task
I can't even get past this step....  There is no program called 'Add scheduled Task'....  However there is a Task Scheduler...  and since there is no browse option in the Task scheduler as described in step 2 what is the next step?  Create a basic task?...  Create an advanced task?  Import a task?  any help or link to better documentation would be greatly appreciated.
