Pull Thin AP information from WLC
I'm looking for a way to pull certain information of APs associated with a Cisco WLC.  Mainly looking for model #, version, serial number etc.
Using the Universal Device Poller I see the OIDs for this information, but I would like it to be all in one table.  Is there a way to combine it into one table?
APname 1.3.6.1.4.1.14179.2.2.1.1.3
APLocation 1.3.6.1.4.1.14179.2.2.1.1.4
APSoftwareVersion 1.3.6.1.4.1.14179.2.2.1.1.8
APModel 1.3.6.1.4.1.14179.2.2.1.1.16
APSerialNumber 1.3.6.1.4.1.14179.2.2.1.1.17
  • Set these as table pollers and assign them.
    Add a Tabular Universal Device Poller -  Resource
    Then EDIT that resource and check the check boxes of the pollers you want to display in the chart.
    **Apply these pollers to your controller, and add the resource on the controller as well for the associated AP information**
