Some nodes not present in node resource list
I am trying to add some serial interfaces on a Cisco 7206 router to the Node Details page. When I list the resources for the node so that I can select the interfaces to be viewed in the Web Console, they are not there. I tried un-managing then re-managing the node but it did not make a difference. I believe if I rediscover the node, I would loose my statistical information which I have to avoid at all costs as this is a core node. Any suggestions on how I should proceed?
  • The List Resources function is done in real time against the devices, so if they are not show in that list, then they are not present in the IF-MIB.  You can do a MIB Walk to confirm this, but if they are in another MIB you will need to create a UNDP.
