This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
Google Maps in Orion NPM - How to Video
I've made some changes to the original Google Maps that I introduced about this time last year. This version provides a status icon on the map for each unique latitude and longitude value in the database. I'm leaving the old one up as it is better for environments where a large number of sites exist, and would simply be too cluttered with a status icon at each site.
Prerequisites:
1) Obtain Google API Key for Maps v3
2) Create and populate Custom Properties:
  • Country
  • City
  • Latitude
  • Longitude
Installation:
Copy files to the c:\inetpub\SolarWinds\Orion\GoogleMap\
Update your connection string and API key
Create a view in NPM using the Custom HTML resource, configure iFrame
See the movie (how to install the mod):
2013-07-25_10-43-25 - YouTube
Read the book (asp files, readme, notes on GitHub):
https://gist.github.com/BarefootAtomic/a396a12541ff97a2ce1f
Enjoy!
Andrew LaGrone, SCP#1368
GoogleMap1.4.zip
