Deleting old IOS file from Cisco 2960x switch using a Orion Script
What would be the script to delete old IOS file from Cisco 2960x switch flash.
Following is the command which I run manually on each switch to make space and would like to process it through Orion script as we got 100+ devices.
delete flash:c2960x-universalk9-mz.152-7.E4.bin
  • Are you creating your own change template or using our out of the box firmware upgrade wizard/process?
  • As long as the command would be the same one each device and you are removing the same FW file
    If I am not mistaken the command would be issued from the Priv Exec (hostname #)
    As long as NCM is able to log into the device, get to the priv exec level, and the User set up in NCM has the permission level to execute this command
    Then:
    In the Configuration Management Page
    Select the nodes you want to run this command on
    Select Execute Script
    add the command to the script
    Execute
    NCM would run the command against each device selected
    Also if you wanted to verify the bin file was removed
    you may tack on the command  dir or show flash
    like so:
    dir
    then execute
