Opengear NCM Device Template using port 3004
I am trying to add an Opengear console server to NCM to run commands on a specific port (3004) wich is connected to a power PDU.  The idea is to be able to turn off power to a specific device.   I created a connection profile and changed the SSH port from 22 to 3004.   Regretfully the connection profile test fails ( Test Failed. Connection Refused by).    If I use the standard SSH port the test passes.    If I use SecureCRT with 3004, I notice that I have to hit enter before commands are displayed.
This is the current device template that works with SSH 22 but not 3004.   Any ideas?
<Command Name="VirtualPrompt" Value="$"/>
<Command Name="RESET" Value=""/>
<Command Name="Reboot" Value="reboot"/>
<Command Name="EnterConfigMode" Value=""/>
<Command Name="ExitConfigMode" Value=""/>
<Command Name="Startup" Value=""/>
<Command Name="Running" Value=""/>
<Command Name="DownloadConfig" Value="cat /etc/config/config.xml"/>
<Command Name="UploadConfig" Value=""/>
<Command Name="EraseConfig" Value=""/>
<Command Name="SaveConfig" Value=""/>
<Command Name="Version" Value=""/>
<Command Name="AllocatePty" Value="true" />
