Hi All,
I'm trying to get NCM to back up a switch but I'm getting this error:- -sh: show: not found
We've created a new device profile which allows NCM to logon, we just cant seem to work out how to backup the the config from here, any pointers would be great, I've tried showing the running config but as you can see show is not a recognised command.
<Configuration-Management Device="Cisco Devices" SystemOID="1.3.6.1.4.1.9.1.2404" AutoDetectType="BySystemOid">
<Commands>
<Command Name="EnableCommand" Value="system support diagnostic-cli" />
<Command Name="RESET" Value="" />
<Command Name="MenuBased" Value="false" />
<Command Name="UseVirtualPromptForCommands" Value="true" />
<Command Name="Startup" Value="" />
<Command Name="Running" Value="" />
<Command Name="DownloadConfig" Value="show" />
<Command Name="Version" Value="telnet localhost ${CRLF}enable ${CRLF}" />
<Command Name="CCTV SW Backup" Value="" />
</Commands>
</Configuration-Management>
Martyn
