Does anybody know how to remotely add VLANs to a RuggedCom RS900 switch? I have used the templates presented here to download config files into the repository but have been unable to push and commands to the switch to modify their configuration. I have been able to come up with the following commands that works locally on the switch from CLI, just not able to run from NCM. I have modified the config template to the point of getting to CLI then added these lines:
sql INSERT INTO vlanStaticCfg VALUES 101 None off 0 active
sql UPDATE vlanStaticCfg set VLAN_Name=batman where VID = 101
