NCM ACL Script
Hi guys, need some assistance please with a script to add ACL entries in bulk to Cisco switches.
conf t
No access-list 11
access-list 11 permit 10.81.3.194
access-list 11 permit 10.117.14.1
access-list 11 permit 10.81.129.29
access-list 11 permit 10.81.224.81
access-list 11 permit 10.25.64.0 0.0.31.255
access-list 11 permit 10.116.0.0 0.0.3.255
access-list 11 permit 10.116.80.0 0.0.1.255
access-list 11 permit 172.30.0.0 0.0.31.255
access-list 11 deny   any log
No access-list 12
access-list 12 permit 10.81.3.194
access-list 12 permit 10.117.14.1
access-list 12 permit 10.81.129.29
access-list 12 permit 10.81.224.81
access-list 12 permit 10.194.24.0 0.0.0.255
access-list 12 permit 10.25.64.0 0.0.31.255
access-list 12 permit 10.116.0.0 0.0.3.255
access-list 12 permit 10.116.80.0 0.0.1.255
access-list 12 permit 172.30.0.0 0.0.31.255
access-list 12 deny   any log
end
wr
Script fails on validation
Validation Failed: An error occurred during script parsing. Position: Line 1, Character 1 Error message: mismatched input 'conf' expecting SCRIPT keyword Please check script syntax.
  • have you tried putting the whole command instead of the short version?
  • Thanks for the response, yes no difference.
  • do you mind posting a screenshot of where you are attempting to run this?
  • Edited the script and Passed validation, have asked Engineer to test.
    .CHANGE_TEMPLATE_DESCRIPTION
            Change Access List on Cisco IOS devices
    .CHANGE_TEMPLATE_TAGS
    Cisco
    .PLATFORM_DESCRIPTION
            Cisco IOS
    .PARAMETER_LABEL @ContextNode
            NCM Node
    .PARAMETER_DESCRIPTION @ContextNode
            The node the template will operate on.  All templates require this by default. The target node is selected during the first part of the wizard so it will not be available for selection when defining values of variables.
    script ChangeACLCiscoIOS (
                                               NCM.Nodes @ContextNode)
      CLI
    configure terminal
    No access-list 11
    No access-list 12
    end
    wr
