Netflow URLs to widgets - how to create them
Do you want to go direct to the charts for traffic to an IP, or application?  The following URL formats I found out when working on my F5 Dashboard.  I wanted to put in some interactivity  - when clicking on a virtual server would show you the Netflow app and conversation widgets.
I also wanted to put in some direct links to save people opening up the main Netflow pages, and searching.
Lookup traffic to/from an IP for the last 2Hrs – 170.20.95.11
/Orion/TrafficAnalysis/SummaryView.aspx?NetObject=NSF:T:Last%202%20Hours;FD:Both;IPV:Both;E:170020095011
If you can't see it, each octet of the IP address gets converted to a 3 digit number, and all the dots get revoved.  You can do this with SWQL, though it takes several steps.  (see my F5 dashboard code for an example of how I create this URL)
Lookup traffic to/from an IP group (IP group 4):
/Orion/TrafficAnalysis/SummaryView.aspx?NetObject=NSF:T:Last%202%20Hours;FD:Both;IPV:Both;G:4
This was useful for a link to VPN traffic.  Just create the group, note the ID, then put it in the link.
Top 5 applications for the IP Group (IP Group 4)
/Orion/DetachResource.aspx?ResourceID=1483&NetObject=NSF%3aT%3aLast+2+Hours%3bFD%3aBoth%3bIPV%3aBoth%3bG%3a4
Similar to the above.
Detailed page for traffic passing through an interface
/Orion/TrafficAnalysis/NetflowInterfaceDetails.aspx?NetObject=NI:9999
Replace 9999 with the interface ID.
