Hi.
Relatively new the Thwack and NTA so grateful for some advice - mainly on applying Net flow to interfaces.
I am aware of the possibility of duplicate flow data if applied incorrectly to multiple interfaces but most examples don't quite mirror our setup. Basically we have switch stacks with 2 up-links to core switches as shown in my attached diagram. Data may flow from either or both. Therefore I have configured each interface to send flow data as shown below. This config seems to be working fine but I want to be sure I am collecting correctly.
I appreciate any thoughts and advice you can give:
flow record NTARecord_Ingress
match ipv4 tos
match ipv4 protocol
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
match interface input
collect interface output
collect counter bytes long
collect counter packets long
Collect timestamp absolute first
Collect timestamp absolute last
flow record NTARecord_Egress
match ipv4 tos
match ipv4 protocol
match interface output
collect interface input
flow exporter NTAExporter
destination (Solar Winds Web Server)
source Loopback0
transport udp 2055
flow monitor NTAMonitor_Ingress
cache timeout active 60
flow monitor NTAMonitor_Egress
interface GigabitEthernet1/1/1 and G2/1/1
ip flow monitor NTAMonitor_Ingress input
ip flow monitor NTAMonitor_Egress output
