I'm trying to match on the following pattern in traps in Log Analyzer. Can't get anything to work with regex. The LA rule config refers me to "C# Regular Expression reference" which is not found on the support site. This works on regex101.com: cerent454AlarmState\..{1,8}\.5880 = 40 when I copy the pattern directly out of Log Viewer, but it does not work in the rule config.
The pattern appears as this in Log Viewer:
