I currently have a Case with SW and figured I'd bring it to this forum to see if anyone else has had the issue. We upgraded to the latest version of Kiwi Syslog and now the Web Access login is broken. The application hosted on our servers confirms that they are still collecting logs. However, when we try to use the Web Access portal, the authentication method is broken. Instead of just being able to insert our AD credentials at login, we're prompted for Windows Auth credentials first. After you log in that way, you then get to log into the Web Portal. The previous and expected behavior is just go to the URL and insert our AD credentials and get access to the site. If we disable windows auth in IIS, the page can't load at all getting errors.
