Hello,
Currently my log to file path is: C:\KiwiSyslog\%HostName\%DateISO.txt
However, I want the path to be C:\KiwiSyslog\%HostName\%CustomVariable01\%DateISO.txt
I am trying to write a script where the custom variable is assigned a value depending on the HostIP Address (if %HostName is 00.00.00.000 then CustomVariable01 is "XYZ").
This is the script I have-
function main(){
var HostName= VarPeerAddress;
var customVariable= "undefined";
if (HostName= 00.000.00.000)
customVariable="XYZ";
return customVariable;
else
var customeVariable= "unidentified";
VarCustom01 = customVariable;
return "OK";
Can someone help me with the correct syntax of the JScript? Thanks
