I'm new to CatTools. I'm running version 3.4.0. Most jobs seem to work fine. However, I am trying to automate a push of my QoS settings. The config drops fine when dropped into the router manually. However, I get the following error when pushed from CatTools:
The following command is invalid: class-map match-any Telnet
The job aborts after the first error. This command is fine and works manually. I tried to enter the commands via a file also but I got the same results. I also tried to enter the related access list definitions prior to the class map commands. However, I got the same result on the first acl command.
Any assistance would be greatly appreciated. I've pushed it to about 30 of my 300+ routers so far and I really don't want to do the rest manually.
Thanks!
Paul
