problems backing up running config of cisco nexus 5020
does anyone have any suggestions to help ? it worked 2 days ago, but all of the sudden it stopped working, very strange-
<NEWSESSION CatTools 3.6.0 3/3/2012 7:32:52 PM>
<PROTOCOL=Telnet>
<DEVICE TYPE=Cisco.NXOS>
<ACTIVITY TYPE=Device.Backup.Running Config>
<ACTIVITY SCRIPT=C:\Program Files\CatTools3\Scripts\Client.Device.Backup.Running Config.txt>
<USERS NAME FOR DEVICE=DATA-01-A-SW01>
<C OK 7:32:52 PM><R-7:32:53 PM>[07]DATA-01-A-SW01[07]Data Center North 1 Switch[07]Nexus 5020 BC[13][10]login: <W-7:32:53 PM>vcradius[13]<R-7:32:53 PM>vcrad[13][10]<R-7:32:54 PM>Password: <W-7:32:54 PM>ibe[13]<R-7:32:54 PM>[13][10]<R-7:32:54 PM>Cisco Nexus Operating System (NX-OS) Software[13][10]TAC support: www.cisco.com/tac[13][10]Copyright (c) 2002-2010, Cisco Systems, Inc. All rights reserved.[13][10]The copyrights to certain works contained in this software are[13][10]owned by other third parties and used and distributed under[13][10]license. Certain components of this software are licensed under[13][10]the GNU General Public License (GPL) version 2.0 or the GNU[13][10]Lesser General Public License (LGPL) Version 2.1. A copy of each[13][10]such license is available at[13][10]www.opensource.org/.../gpl-2.0.php and[13][10]www.opensource.org/.../lgpl-2.1.php[13][10]<R-7:32:56 PM>[13][00]DATA-01-A-SW01# <W-7:32:56 PM>[13]<R-7:32:56 PM>[13][00][13][10]<R-7:32:57 PM>[13][00]DATA-01-A-SW01# <W-7:32:57 PM>terminal length 0<R-7:32:57 PM>terminal length 0<W-7:32:57 PM>[13]<R-7:32:57 PM>[13][00][13][10]<R-7:32:57 PM>[13][00]DATA-01-A-SW01# <W-7:32:57 PM>show running-config<R-7:32:57 PM>show running-config<W-7:32:57 PM>[13]<R-7:32:57 PM>[13][00][13][10]
WFMDRetVal=1 Waiting for: "--More--"
WFMDRetVal=2 Waiting for: "% Invalid"
WFMDRetVal=3 Waiting for: "% Incomplete command"
WFMDRetVal=4 Waiting for: "(y/n)"
WFMDRetVal=18 Waiting for: "DATA-01-A-SW01>"
WFMDRetVal=19 Waiting for: "DATA-01-A-SW01#"
WFMDRetVal=20 Waiting for: "DATA-01-A-SW01("
WFMDBuffer="[13][00][13][10]"
<W-7:35:27 PM>[13]<W-7:35:35 PM>exit[13]<D 7:35:35 PM>
<SCRIPT VALUES>
<HOSTNAME="DATA-01-A-SW01">
<PROMPT VTY="DATA-01-A-SW01>">
<PROMPT ENABLE="DATA-01-A-SW01#">
<PROMPT CONFIG="DATA-01-A-SW01(">
  • Hi thewizards2k2
    CatTools is connecting fine and sending the correct command, however it appears the device is simply not responding back with any command output.
    Has anything been changed on the device recently (O/S upgrade maybe?)
    Regards,
    Steve
  • steve,
    Thank you for the quick response. I also thought about checking to make sure there was no O/S upgrade. But no, there was no  O/S upgrade. I even checked the running configs to see if we added any extra lines of commands, but nothing, Everything (o/s and run-config ) is the exact same. So after verifying that, i started to mess around with the variation features. And under "additional commands", "disable paging," i added "terminal length 2200." After doing that, it can now back-up running config  with no problems.  it makes no sense, to me why this would work but not terminal length 0. is it some sort of bug in cattools? Does the new RC release address this?
  • When you startup the CatTools manager UI, there should be a debug level-4 message in the Info Log pane which states the version of the 'Protocol Engine'.
    Could you confirm which version is says it is currently using please?  (2.x.x.xx?)
    Steve
