Disable annoying prompt about host name mismatch
Is there a setting in dameware to make this go away?
Possible Name Resolution Conflict
The remote computer reported its host name to be different than the host name (computername) you used for this connection
Computer name: (the computer name I typed in)
IP Address: the IP address of it
Continue
yes / no.
The answer will always be yes.
Dameware Mini Remote Control 12.1.1.273 64-bit
