Central Server - Active Directory SSO
We use Central Server and it's been working absolute fine.
I've moved the Central Server install to a new server (deactivated licenses on old one first) but clients are getting this:
"dameware central server was unable to validate entered credentials"
I use the AD Import task to bring in the users I want and have given them access.
What am I missing?
Top Replies
  • Hi ldoodle​,
    unfortunately the AD Importer will only create DameWare based users, so no SSO ( and I have no idea what the default password they're set to is )
    If you want to use SSO you'll have to use…
  • Hi ldoodle​,
    If you want to use SSO you'll have to use the AD Manager and create a synchronizer instead. That way the users will actually be able to use SSO.
    Best regards,
    Ed.
