PowerShell Component Monitor - returns Undefined
Hello,
I am creating an Application Template with a PowerShell Component monitor. It's a verification that clients can upload to an sftp site.
I have a test account called SOLARWINDS and it has secure cred file that are using in the session. The PS Component is set to run on the Remote Host.
The PowerShell code works on the test machine through various tests.
When I add the PowerShell Component monitor to an Application Template and test it against the same Node, it returns undefined.
I am hoping to know where the code is having the issue in the Component Monitor.
# SolarWinds Application Monitor#
# Requires WinSCP (All Users)   #
# Load WinSCP .NET assembly
Add-Type -Path "C:\Program Files (x86)\WinSCP\WinSCPnet.dll"
# setting locations for sftp file transfers
$localDirectory = "C:\TestUpload\"
$remoteDirectory = "/"
# setting location of Secure creds
$KeyFile = "C:\scripts\sftp-upload-securecreds\Auxiliary_Files\sftp-transaction-connect.key"
$PasswordFile = "C:\scripts\sftp-upload-securecreds\Auxiliary_Files\sftp-transaction-connect-SOLARWINDS.password"
# getting secure creds for the SOLARWINDS user account
$ServiceAccountCredentials = Get-SecureCreds -AccountName SOLARWINDS -KeyFile $KeyFile -PasswordFile $PasswordFile
# Set up sftp session options
$sessionOptions = New-Object WinSCP.SessionOptions -Property @{
    Protocol = [WinSCP.Protocol]::Sftp
    HostName = "mb.payments.ca"
    PortNumber = "22"
    UserName = $($ServiceAccountCredentials.UserName)
    Password = $($ServiceAccountCredentials.GetNetworkCredential().Password)
    SshHostKeyFingerprint = "ssh-rsa 2048zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz"
# SCRIPT START #
    # Create session
    $session = New-Object WinSCP.Session
    # Connect
    $session.Open($sessionOptions)
    # Wait for 5 seconds before getting $connectionStatus
    Start-Sleep -Seconds 5
if ( !$session.Opened)
    write-host "Statistic: 1"
    Write-Host "Message: Can't sftp connect to $sessionOptions"
    exit 1
  else
    # Transfer files from local to remote
    $transfer = $session.PutFiles("$localDirectory\*", "$remoteDirectory/")
    if ($transfer.IsSuccess -eq $true) {
        write-host "Statistic: 0"
        write-host "Message: sftp file transfer complete."
        exit 0
    write-host "Message: sftp file transfer failed"
    exit 1
  • My guess without running your code is that not all paths are returning a value. Try putting an exit 1 at the very end and see what happens. You should probably wrap your script in try/catch block and handle errors. Also check the log files generated by your app monitor for errors.
  • Does the account have the ability to connect to the remote server?  If you are choosing remote host, then SolraWinds is going to connect to the target to run the shell script.  Are you able to do that with those credentials?
  • Maybe something like this...and if there is an issue connecting with credentials then your script will return critical and you can look at the contents of Message.Error in the components pane of the Application Details page of the Solarwinds web console or the log file in C:\ProgramData\SolarWinds\Logs_Agent\APM\ApplicationLogs.
    # Solarwinds Exit codes
    # 0                   Up
    # 1                   Down
    # 2                   Warning
    # 3	                  Critical
    # Any other value     Unknown, for example 4
    try {
        if (!$session.Opened)
            write-host "Statistic.Error: 1"
            Write-Host "Message.Error: Can't sftp connect to $sessionOptions"
            exit 3 # Critical
        else
            if ($transfer.IsSuccess -ne $true)
                write-host "Message.Error: transfer error."
                exit 3 # Critical
    catch {
        Write-Host "Statistic.Error: 1"
        Write-Host "Message.Exception: $($PSItem.Exception.GetType()) $($PSItem.Exception.Message)`r`n$($PSItem.ScriptStackTrace)"
        exit 3 # Critical
    # if we got here then success!
    # 0 = Up = script ran successfully
    exit 0
