Python using SwisClient returns error "SwisClient.update() takes 2 positional arguments but 3 were given"
I have a Python script that I am trying to disable the NCM Management, when I run the script it returns the error of "SwisClient.update() takes 2 positional arguments but 3 were given", how do I resolve to issue?
Here is the Python:
import Express_Config
from orionsdk import SwisClient
# Replace with your SolarWinds server details
server = 'hqnpmapp4.expresspersonnel.com'
username = Express_Config.OrionUser
password = Express_Config.OrionPss
swis = SwisClient(server, username, password)
node_id_to_update = Express_Config.node_id_to_update
node_name = Express_Config.node_name
# Connect to Orion
query = f"SELECT Uri FROM Orion.Nodes WHERE NodeID = {node_id_to_update}"
results = swis.query(query)
uri = results['results'][0]['Uri']
properties = {'ManageNodeWithNCM': 'No'}
try:
swis.update(uri, properties)
print(' ')
print(f"Successfully Disabled NCM Node management for '{node_name}'.")
print(' ')
except Exception as e:
print('**************************************************************')
print(f"Error disabling NCM node management: {e}")
print(properties)
This is the error that it returns.
Error disabling NCM node management: SwisClient.update() takes 2 positional arguments but 3 were given
