Hybrid Cloud Observability Enterprise Advanced Scaler
Why does it consume a lot of space in SQL Server?
I Just config 7 days of retención for 300 devices.
Does anyone know what good practices, I would like to be able to do one:
1.- Data storage configuration
Adjust data retention so that old records are removed and configure databases to only grow to a certain size.
2.- Cleaning the database
Delete unnecessary or duplicate records to avoid database overload and improve Log Viewer performance.
3.- Search filters and alerts
Set up search filters to quickly find the records you need, and set up alerts to get notified when certain conditions are met.
4.- Customizing the display of the records
Adjust the view of the records according to your needs, grouping them by different fields and customizing the appearance of the application.
5.- Optimization of the use of resources
Configure the amount of resources that Log Viewer uses, to avoid affecting server performance.
By other part, I wish to how is the best plan for.
I.- Log Viewer update
Make sure you have the latest version of Log Viewer to take advantage of the latest features and bug fixes.
II.- Test environment
SolarWinds offers a free trial environment to practice using Log Viewer. You can also find tutorials and samples online to practice using the tool or install it in a test environment on your own computer.
